Input as Pi?
All  1  2-6
3517.2 In reply to 3517.1
Just type inside Moi 22/7 ;)
3.142857
or better 355/113 You win again one key press enter :)
3.141593 display on the screen maybe internal decimals are more large?
if you type 355/113 inside the research text of Google it gives that ;)
3.14159292
http://www.google.fr/#hl=fr&q=355%2F113&meta=&aq=f&aqi=&aql=&oq=355%2F113&gs_rfai=&fp=c735c1c711fe9f01
My window calculator gives me that ;)
EDITED: 5 May 2010 by PILOU
3517.3 In reply to 3517.1
Hi Nick, yes in v2 you can enter in numeric expressions, and you can use PI (all capital letters) for that constant.
So for example when drawing a circle if you want to enter PI in for the radius value, first push the Tab key to set keyboard focus to the Radius: field (or click on that field) and then type PI and push Enter.
If you enter in numbers, it is not necessary to push Tab first, because when you type numbers they go directly to any available numeric input and put focus on it automatically. But if you want to type in some expression that starts with a letter, push Tab first to put focus there because letters are usually reserved for keyboard shortcuts so they won't automatically be taken into a number input field unless the keyboard focus is already on the field.
There are also other math constants available as well like E or SQRT2, there is a list of them here:
http://msdn.microsoft.com/en-us/library/shydc6ax.aspx
3517.4 In reply to 3517.3
CAPITAL letters was the trick ! :)
3517.5 In reply to 3517.4
I've set it up now so that Pi or pi will work in addition to PI.
3517.6
DITTO! (Also in ALL CAPS). :-P
Mmmmm, pi.
Thanks.
-Nick
Show messages: All  1  2-6
