Rhino + T-Splines and MoI 3D ?
 1-4  5-21
3513.5 In reply to 3513.4
Thanks for all the answers :)
The only thing I need is T-Splines for complex shapes that I don't know how to make in MoI 3D beside building tons of construction curves
So the workflow is doing some parts in T-Splines and then boolean them together using MoI 3D
Also Michael, we need something like Auxpecker for MoI 3D :)
Its so awesome to work with and so usefull to get more visual feedback
Too bad T-Splines is not a standalone software :(
3513.6 In reply to 3513.5
Hi DesuDeus,
Yup, that direction (T-Splines to MoI) should work fine.
There is a T-Splines command: tsConvertToRhinosurf which converts a T-spline object into a just a regular Rhino NURBS object.
It looks like T-Splines will automatically do that conversion in many cases as well, but I'm not sure if it will do it for copying stuff to the clipboard or not. You may need to run the tsConvertToRhinosurf on your T-Spline first before copying it.
3513.7 In reply to 3513.6
Hello,
This t-spline technology looks like a pure dream for many poly modeler users, it will help to make the bridge
between MoI and any poly modeling package for some specific project.
I'm wondering how complex the 'convert poly sds cage into nurbs' is, as basically, it's the only function
I think usefull for my workflow needs. Well it 'seems' to be handy, has I never really try it for a real
project.
I know T-spline is a much more complex bunch of commands inside rhino, from 't-spline' surface creation,
to many tools that somehow convert rhino into a polygon modeler. But what about just focusing on this command ?
Would be a dream to import a poly-model into MoI, and convert it into nurbs. Aren't they any
free/open source work available than will help to have this functionnality into MoI ? Or does it require some alien technology
and years of developement ?
I know for example that Maya can do that kind convertion since years, turning an sds model into a nurbs one, the only difference is that the surface is
a little bit more complex that using tspline, there are more isocurves ? (not sure if it's the good term) to describe the
surface.
For sure, a maya licence or a rhino + tspline one just to do some converstion from time to time will overkill my budget :P
Maybe in MoI 5 ? ;)
3513.8 In reply to 3513.7
Hi PaQ, well one thing I've suggested to the T-Splines guys is to have a standalone converter program that would read an OBJ file and generate a sub-d NURBS 3DM file from it.
It could probably have a minimal UI... If that sounds like it would be useful you might try contacting them and asking about it.
Well actually there is a simple direct conversion on completely regular quad areas, where every vertex has only 4 edges coming off of it. Quads in areas like that can have a NURBS surface sub-d patch created directly.
It's in areas where there are other than 4 edges radiating out from a vertex where there is not a simple direct conversion possible, so those areas tend to need a more complex fitting/approximation type mechanism to fill them in with NURBS surfaces.
3513.9
The patches created by T-splines ARE very complex. But modeling with T-Splines is real fun. Specially because OBJ files can be converted to T-Splines....
Don't use to dense of a mesh or the benefits go away. But some base form created in a poly modeler is easily loaded into T-Splines.
Rainer
3513.10 In reply to 3513.9
I knew nothing about T-Splines before reading this thread and I must say, it looks pretty interesting.
I'm sure Michael and everyone else already knows this but the T-Splines people are licensing the libraries, apparently the same ones as used to develop the Rhino and Maya plugins.
http://www.tsplines.com/products/t-tools-libraries.html
Mark
3513.11
Hello Friendly
I enclose you some Images of a Shape
modeled in Rhino with Tspline ;
it is possible imported it within MOI with simply Copy and Paste
Before to import the Shape ones within MOI it is possible
to define as to convert in Polisurf Entire Superficial TS
al
3513.12 In reply to 3513.11
Thanks Speedy
Its a very good example !
How do you make the sharp edges ? Is it like subd modelling where you add edge loops ?
Its very interesting to build the shape like that and then use MoI for the other things like booleans :)
3513.13 In reply to 3513.11
Hi Speedy,
Thanks for doing this example, looks like a very useful tool, if you don't mind could you separate the surfaces in MoI and show the control points so we can get an idea of the structure of the surfaces or posting the model would be even better.
3513.14
Thanks Speedy
Like a subdivision modeler ( ?! and seems better result than catmull-clarck algo )
3513.15
Hi Everyone,
I don't actually have T-Splines, but I do subscribe to their Newsletter to get info about their product.
Call it good timing because today I received the May Newsletter offering a case study & also 51 Free models.
Here's the link to the case study on doing a jewellery piece:
http://www.tsplines.com/community/casestudies/jewelrydesign2.html
Lifted from the T-Splines site:
Download these 51 freeform models that can be exported and read in as an IGES or STEP into any CAD program. These models were created using T-Splines. You do not need to have T-Splines installed on your computer to read the files--they will open as watertight, dumb NURBS geometry in any program that can read in .3dm (Rhino) files. To edit the models, download a free trial of T-Splines.
Here's the link for the offer of 51 Free models...
http://www.tsplines.com/tsplinemodels.html
HTH, Colin
3513.16 In reply to 3513.15
Thanks for all the infos :)
Some of the models are really good and would be hard to build using only regular Nurbs toolset
3513.17
Hi Friends
Attached the file
for see the topology surf
of the Shape-
al
3513.18 In reply to 3513.8
Thanks for the info,
I'll drop a little mail, I didn't realise that there is a crease edges system too in T-spline, and I suppose it's something that can't be translated from the .obj using a 'simple' translator.
3513.19 In reply to 3513.17
Thanks al.
3513.20 In reply to 3513.18
Not directly no, but if you ConvertToNurbs in the T-Splines toolset first, you can export that geometry just fine. Whether it was creased when it was still t-splines or not. The creasing does flow compatibly into the conversion to Nurbs.
3513.21 In reply to 3513.7
So, we recently released a new trial that works on 25 saves instead of 30 days. So if you only need to do a very occasional conversion, it might work better for you.
Subd -> Nurbs conversion has several potential gotchas. That said, I think there's 3 packages that do it that I'm aware of - Maya, T-Splines, and Catia Imagine & Shape. Perhaps SDlib? I've never been able to find an I&S user to talk to about the quality of the conversions. The T-Spline conversions don't handle creasing very well at the moment. Maya has problems with valence 6 and higher. I'd imagine the SDlib conversion is similar to Maya's, I think it's the same author.
Show messages:  1-4  5-21
