Drawing screws and bolts
All  1  2-5
3505.2 In reply to 3505.1
Hi Mark, if you want some standard bolts and nuts, you might be able to find stuff like that in a parts library rather than actually drawing them at all. Then you just import those parts from already existing model files.
Check out this previous thread for some links to some different libraries:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1826.1
3505.3 In reply to 3505.1
Hi Mark,
I've uploaded the Hex nuts and bolts Here , I took them off the thread Michael mentions, I was supposed to build some more types but never got around to it, I'll do it one of these days :)
3505.4 In reply to 3505.1
Hi Mark, one other thing that I should mention is that you often times may want to avoid actually modeling little tiny but heavily detailed pieces such as the screw threads on a bolt if you have a whole lot of them in your model.
The surfaces that make up threads like that will be pretty heavy with a lot of control points in them, so they take up a fair amount of memory size for each one. If you then have say hundreds of those (with them all actually not even visible), that will end up making for a very heavy model, affecting things like redraw time, memory consumption, and file size on disk.
If you don't have a whole lot of them, and you are using a few of them for a detailed zoom in view or cutaway illustration or something like that, then that kind of thing is fine.
3505.5 In reply to 3505.1
There's a script for Blender that creates nuts and bolts.
http://sourceforge.net/projects/boltfactory/
Steve S
Show messages: All  1  2-5
