construction planes
All  1-2  3-6
350.3 In reply to 350.2
hello michael- I'm amazed! Your reply comes lightning fast :) ...concerning thoose construction planes I have to say that I'm very pleased by the sketchup-peoples approach.
I guess you have played around with sketchup a bit - did'nd you? Well - it obviously is that combination of real construction lines and the 'auto-aligning' feature which is mainly responsible for
being able to work so incredibly fast with sketchup. Lets assume a simple example: You build a cube and apply some fairly big champfers to it, resulting in almost evenly shaped planes
all over the object. What if I wanted to draw on one of the champfered sides directly...? I would zoom to it and would then like to align my construction plane with that champfered side of
the object to be able to construct/draw on it ...then extruding the detail vor example. May be I missed it as yet because I just found MoI, but that would be an 'aligning/rotating-job' for the time being.
Am I wrong? To my 'newcomer'-knowledge :) I would have to construct in any orthogonal view and then 'rotate' or 'align' the sketch into the desired plane - right? That's what I was talking about
In CAD-Systems you would immediately define your construction plane either by just clicking a face or selecting 3 points or two edges and 'voila' you would be able to draw onto that
face/plane. Probably I did'nd take time enough to study the forum hints or the instructions ? :) I'm sure there is a nice workaround or I just did'nd find the right hotkeys as yet.
Anyway I appreciate your prompt answer and I will go on playing around and focus on MoI...By the way - I'm working with wacom tablets since almost ten years now and I like the idea of a piece of software that aimes at people like me too. The MoI-UI even tops the rhino UI...rhino being my main application.
later klaus
350.4 In reply to 350.3
Yes, certainly!
> feature which is mainly responsible for being able to work so incredibly fast with sketchup.
Yes, these are definitely really great for doing boxy type architectural shapes. But they don't really do anything for you if your object has curved surfaces instead of a lot of planes.
Certainly in this case a construction plane is very helpful!
Do you often create models where you want to draw on the chamfers of a box, though?
This just doesn't seem to come up really too frequently, that's why I have postponed this for a little while. Not because I don't think it is useful - there certainly are several circumstances where it is useful, it is just an area of somewhat less frequent use, and less frequently used features are more possible to postpone for a while. Postponing things helps me finish a version 1.0 ! :)
> for the time being. Am I wrong? To my 'newcomer'-knowledge :)
Nope, you're not wrong, it is true that it would require aligning and rotating right now.
Well, the workaround is to just rotate such a piece into place! :)
If you only need to rotate a few pieces around it is not really a terrible problem... If you need to do a whole lot of these kinds of things then probably Rhino will work a lot better for you until MoI gets the cplane support in.
Thanks, I'm glad you like the UI! Part of the reason the UI works well is that I'm kind of slowly adding things in, so I find good spots for things (and ways of combining multiple things into one tool) instead of just jamming too much in really quickly. That's another reason why some things are missing such as construction planes, but they will come in time!
350.5
Maybe not camfered sides, but being able to draw on a plane/surface would be very useful.
There is all sorts of paneling/line detail/geegaws/greebles that I'd like to do that are somewhat tricky with MOI as it stands.
This model was done in Rhino by John Bear Ross, and is a tank for the CAV miniatures game.
http://www.hellionproductions.com/wolverine1.jpg
This would be killer for raised panels, quick insets, etc.
350.6 In reply to 350.5
Yup, it will get there eventually.
There are just some more simple things to finish up first before getting to this.
Show messages: All  1-2  3-6
