No Key Shortcut...
 1-2  3-22  23-33
35.3 In reply to 35.2
Oh yeah, I forgot to say look for the [Shortcut Keys] section in the .ini
Your "Application Data" folder may be hidden, if you don't see it just type it in anyway to go inside of it.
35.4 In reply to 35.3
Ok for these
Ctrl+A=script:moi.geometryDatabase.selectAll();
Ctrl+C=CopyClipboard
Ctrl+N=New
Ctrl+O=Open
Ctrl+S=Save
Ctrl+V=Paste
Ctrl+Y=script:moi.command.redo();
Ctrl+Z=script:moi.command.undo();
Delete=Delete
F1=script:moi.launchHelp();
but for functions like "Extrude" or "Rotate" is it now possible to make a ShortCut? Simply R = Rotate ?
Sorry for my lacks on this domain :)
Hehe Seems Yes! I have try with R = Rotate, E=Extrude etc...That works , I am maybe a genious :D
PS A very cool free Editor is PsPad http://www.pspad.com/en/ Multilanguages :)
EDITED: 30 Aug 2006 by PILOU
35.5 In reply to 35.4
Cool, I'm glad you figured it out!
I don't have a good list of all the command names right now, but if there is a button that you want to make a keyboard shortcut for, you can look in the UI files to find the button and the command name will be present there.
Say for instance you want to have a shortcut for the "Show pts" button. This one is not quite as simple as Extrude or Rotate, because the label on the UI button is not the same as the actual command name.
But if you go to your Program Files / MoI directory, there is a /ui sub directory in there. Go in there and open up SidePane.htm, there you will find the markup for the right-side panel of MoI. Go find "Show pts", and you will see this:
<td><moi:CommandButton style="icon:icons/ShowPointsIcon.png;" command="showpoints">Show pts</moi:CommandButton></td>
So what you're looking for is the command="" item, so in this case "showpoints".
There are a few commands where the text on the button has been abbreviated and doesn't exactly match the real command name like this.
By the way, if you want to rearrange parts of the UI, you can edit the UI files to remove or change where buttons are at. If you change the SidePane.htm file, for instance, you are changing the actual definition of the UI in MoI (it will be changed the next time you run it). You should probably save a backup before you mess around with it, though. :) The other major piece is CommandBar.htm for the bottom bar.
One other thing for keyboard shortcuts - as you found, you can use just the letter of a key for the key. You can use these names for special keys: UpArrow, DownArrow, LeftArrow, RightArrow, Home, End, PageUp, PageDown, Insert, Delete, Backspace, Space, F1, F2, ... F12. You should also be able to use prefixes of Ctrl+ or Shift+ or Alt+ in any combination (like Ctrl+Shift+A should work).
35.6 In reply to 35.5
Oh yeah, you can change all the text labels in there to French if you want.. You may need to save it as a Unicode text file if you do that. I will eventually have a different way to change the text to different languages (with a string table), changing the UI directly won't work too well when I put out new beta versions, especially if I have done any changes to the UI. But you can give it a try if you want...
35.7
I am trying to make key cuts for the tools and have followed aloong and I'm in the sidepane.html and found the ="booleans". What do I need to enter to assign it to a key(B)? Sorry, I'm not that familiar with HTML, a small pop up in the options tab would be great for non-tablet users to assign keys to the tools.
35.8 In reply to 35.7
Once you know the command name, you have to go to the moi.ini file to assign it to a key.
Make sure you shut down MoI first, then run notepad, and open moi.ini from C:\Documents and Settings\[your user name]\Application Data\Moi\moi.ini
This is the file that stores all of your configuration options for running MoI.
Find the section labeled [Shortcut Keys], and add a new line under it for your key assignment, for example:
[Shortcut Keys]
B=BooleanDifference
U=BooleanUnion
I=BooleanIntersection
Ctrl+A=<.....etc...>
Save the file from notepad, and then when you start up MoI again those shortcut keys should be available. Make sure to remember to shut down MoI first before editing the file though.
Let me know if you have any problems getting this to work. If you can't find what the name of a particular command is, just go ahead and ask me.
There will eventually be something to set this under options, but it will probably be a little while before it is ready.
35.9
Thanks Michael, that worked like a charm. I've attached a simple three step visual for others to look at if they want to do shortcuts if that is alright?
EDITED: 31 Aug 2006 by GRENDEL
Bravo !
Very clear :)
35.11 In reply to 35.9
> if that is alright?
Of course! Thank you very much, I appreciate it. Other people will benefit from your clear instructions.
35.12
Awesome. But what's the command for "Reset All"? I can't find it, and that's something I use on a constant basis. So much so I want to put it on the friggin' spacebar.
35.13 In reply to 35.12
That one's a little different, it's not exactly a command because you can do it while another command is still running.
This will do it:
[Shortcut Keys]
Space=script:moi.view.resetAll();
That's basically a little script macro that will run when you push the space bar.
You've probably already seen this, but just to make sure - when you do the view reset the first time, it will go to the selected objects. If you want to go to all objects instead of just the selected ones, then do another reset immediately and it will switch to all objects.
35.14 In reply to 35.13
Awesome. Thanks for the help.
35.15
OK Michael, what would I need to enter to toggle each of the snaps to a key? :) Grid(on/off), Straight, and Object. I have made a list of all the commands so people won't go looking all over with their Icon, UI name and command name. I'll post the list so it will help with some of the same questions.
35.16 In reply to 35.15
Let's see, those ones also need one of those mini script macros. This will do it:
[Shortcut Keys]
G=script:moi.drawingAids.gridSnap = !moi.drawingAids.gridSnap;
O=script:moi.drawingAids.objectSnap = !moi.drawingAids.objectSnap;
S=script:moi.drawingAids.straightSnap = !moi.drawingAids.straightSnap;
Thanks for assembling the list!
35.17
Here is a quick list for most of the tool names and commands you will need to setup keyboard shortcuts for MoI. Just read the above portion of the thread or the three step walk-thru above. Next to each icon is the function name and then the associated command name which is what you will need for defining your own shortcuts in the moi.ini file.
35.18 In reply to 35.17
And maybe also the Selection All, Deselect all, Inverse Selection will be nice on the list :)
35.19 In reply to 35.17
Very cool Grendel, thank you!
35.20 In reply to 35.18
Grendel's got them on Page #3 of his guide, here they are:
[Shortcut Keys]
N=script:moi.geometryDatabase.deselectAll();
I=script:moi.geometryDatabase.invertSelection();
35.21 In reply to 35.20
This another one by Michael
Select All / Deselect All by the Space Barre !
Add this in "one line" in the section [Shortcut Keys]
Space=script:var selection = moi.geometryDatabase.getSelectedObjects(); if ( selection.length == 0 ) moi.geometryDatabase.selectAll(); else moi.geometryDatabase.deselectAll();
Works like a charm !)
EDITED: 4 Sep 2006 by PILOU
35.22 In reply to 35.20
hi There Michael and All
is it possible To make some numeric command aliases?
(alii?)
i use a mouse left-handed even Tho i am actually right-handed
previous owners/bosses drove me crazy with contradictory infomation
so i keet a clip-board To write everything down with
and i ended up loving To use a mouse left-handed which
leaves The right-hand in The proximity of The keyboard number pad
(not going To mention The other software That i have been using for 18 years)
but This is extremely FAST, numeric input for a command name, Then (if needed)
additional numeric input for etc parameters
i havent downloaded The MOI beta yet, so
(but i am going To do just That as soon as i finish This message)
i am not sure if This is possible or would work
by The way i got 300 - 400 numeric keypad command aliases memorized by now
and (did i say This before) IT IS extremely FAST!!!
vizjunky
Show messages:  1-2  3-22  23-33
