Long names
All  1  2-5
3490.2 In reply to 3490.1
Hi Danny, I'm not really sure what I could do about that - would you expect the browser item to word wrap, or the entire browser panel to widen up dynamically if you have a long name? There are probably going to be difficulties with attempting either of those though.
You can edit the browser (when in it's separate panel mode) to make its regular width to be larger though, if that would help.
To do that open up the file BrowserPane.htm which is in the \ui subfolder under MoI's main installation folder.
Inside that file you will see that the first child of the <body> tag is a <div> that has a bunch of A characters in it, like: AAAAAAAAAAAAAAAAA
That's currently what actually defines the width of the pane, add in like 10 more A characters to that and it will make the browser pane wider.
3490.3 In reply to 3490.1
Maybe in the future the way that issue can be solved would be to take names like "Assembly : Item" and build groups out of them instead of having that as the object name.
3490.4 In reply to 3490.3
Couldn't we have a tooltip type thing when you mouse over the name for a few milliseconds ?
3490.5 In reply to 3490.4
Hi Danny, yeah a tooltip type thing is probably feasible to add in v3.
In some ways I try to avoid tooltips because they kind of force you to browse things one at a time, but in this case it is probably the easiest way to add extended information.
Show messages: All  1  2-5
