V2 beta Apr-16-2010 available now
All  1  2-8
3477.2 In reply to 3477.1
Thanks Michael G. I just downloaded it. I'll give it a spin later tonight.
Michael T.
Michael Tuttle a.k.a. mictu http://www.coroflot.com/fish317537
3477.3 In reply to 3477.1
The script copier utility for this version is attached here.
If you run this utility it will copy plugins that were installed in the commands folder in v1 into the current v2 beta's commands folder so they will then also be installed in v2.
3477.4 In reply to 3477.3
Not sure what I did wrong, but, I tried the script copier to add my customizations from the previous beta,
but it didn't work. I'd also like to add the keyboard shortcuts of the scripts, without typing them all in again.
Jesse
Edit: I must have had a temporary brain freeze..but I just remembered how to do this :-)
EDITED: 26 Apr 2010 by JESSE
3477.5 In reply to 3477.4
Hi Jesse, are you all set up ok now then?
The keyboard shortcuts are stored in the moi.ini file which is by default saved in a central location so your typed-in shortcut definitions should automatically appear in the new version.
What won't appear automatically are custom command files that you may have installed by copying them to the \commands sub-folder. Those need to be copied into the new beta's \commands sub-folder to be installed for the new beta as well. That script copier utility will just automate that by copying any extra files it finds in v1's \commands folder over to the new beta's \commands folder.
3477.6 In reply to 3477.5
I had forgotten that my copy of the previous beta of MoI and ini file with all the script customizations
was backed up on a 2nd hard drive, but once I found it, I managed to get everything working again.
Jesse
3477.7 In reply to 3477.3
I found the script also copied plugins from a previous v2 beta to the APR 16 beta.
Is this the intention? The instructions on the tin only suggest it copies from v1 -> v2beta.
Many thanks,
Hamish
3477.8 In reply to 3477.7
Hi Hamish,
Well, the way it works is it first looks to see if the 1.0 folder in its default install location exists. If it cannot find that, then it will pop up a folder picking dialog box to pick the source location, and if you pick some other v2 beta's install folder as the source location it will use that one's \commands folder as the source.
Show messages: All  1  2-8
