Edit ini-file question
3476.1
Hello Michael,
I really like the presentation or better the color scheme of Moi, but my eyes would prefer to work with a black background color.
I have changed that in the options, but if i draw anything, i draw black on black and i haven`t found the right parameter to change the black of lines into a light grey.
I think i have tried any 0,0,0 parameter, but nothing affects the color of lines.
With lines i also mean the lines used by tools like scaling and so on. They all stay black on black, no matter what i change.
Do you know some workaround for that or maybe did i oversee something?
vinced
3476.2 In reply to 3476.1
Hi vinced - are you using MoI v1 or MoI v2?
In MoI v2 the way colors work are quite a bit different, since objects are not normally all forced to be a single color and instead are colored by what style they have assigned to them.
So in MoI v2 that particular setting that I think you are using does not do anything anymore.
In MoI v2 there are a couple of choices you can use to get what you want though.
One way is to edit the "Default" style to have a different color and then save that to a 3DM file and use that as the startup template file in Option > General > Template file. Then when you start up MoI your styles will be set as you want.
There is also a different setting in moi.ini that you can set to override the curve color instead of having it displayed by style. That's under the [View] section:
[View]
CurveColorMode=ByStyle
CurveFixedColor=0,0,0
Change the CurveColorMode to be =FixedColor and then put in your color value under CurveFixedColor=r,g,b.
There's also the same thing for Edges as well, with EdgeColorMode, and EdgeFixedColor.
Let me know if you have any problems setting this up.
3476.3 In reply to 3476.2
that did it. Thanks for the fast reply.
I`m working with v2 beta by the way.
Now i have just to find a good color that works with most of the styles.
Greetings
vinced
