Questions on IGES for Import
 1-13  14-21
3468.14 In reply to 3468.13
Hi Burr, yeah several different things relating to IGES may not be expecting to work with a single solid getting joined up made up of multiple different colors within it.
Currently when MoI writes out an IGES file it will only write out the single color assigned to the parent object and not colors for individual sub-objects within a joined solid.
Maybe I can look at tweaking this in the future but I'm not so sure that you're going to find it widely supported to get a solid joined result that still has those different colored faces within it.
Having faces with individual colors within a single object is more widely supported in mesh formats so that does work fine with OBJ or LWO exports.
3468.15 In reply to 3468.14
Yeah, it's not something needed I found in a workflow of any kind. Only that I made the mistake and was thinking MoI wasnt writing those colors out. Now that I know it does, I am clear on what is happening.
Thanks again.
3468.16 In reply to 3468.9
Hi Michael T,
Here's another version with the mesh reduced to about the maximum 3D-Coat will allow.
Hopefully this will allow you to do what you're after with it.
But if you need something else with regards to this, then maybe it's best to PM me from here on.
So based on what Michael G has already previously written, I now understand that what I wanted to do wasn't really practical as a workflow.
I'm seeming to find that the style of models I get asked to make, draws me into something that requires a combination of CAD style NURBS & Sub-D work.
I already know what the perfect solution is...buy myself ClayTools or FreeForm from SenAble. http://www.sensable.com/index.htm
But as I'm now doing work more as a "Hobbyist/Jewellery Modeler", I can't justify spending anywhere near that kind of money, even for their basic package.
So I'll just keep battling along trying to develop myself alternatives that'll give me a good workflow for those oddball & sometimes difficult jobs I seem to score.
regards Colin
3468.17 In reply to 3468.12
Michael,
"I'm not quite sure about STEP, I'll take a look at that."
According to the help file in Solidworks, STEP AP203 does not handle colour information. Whereas STEP AP214 does handle colours.
Of course there are a bazillion STEP APs so I don't have a clue about the rest, all I know is 203 is very common and 214 is sort of common too.
3468.18 In reply to 3468.16
Thanks Colin for the new file. I'll check it out and let you know what I come up with.
Thanks Michael G. for the clarification regarding nurbs vs. polygon geometry treatment. I only use these crossovers for reverse engineering purposes for non-exact geometry extractions.
Thanks again,
Michael T.
Michael Tuttle a.k.a. mictu http://www.coroflot.com/fish317537
3468.19 In reply to 3468.17
Hi Kevin,
> handle colours.
It sure would be nice if STEP was not as confusing as government bureaucracy tax forms... :)
Just to make things a little more confusing there is apparently a "second edition" of AP203 that increases overlap with AP214: http://en.wikipedia.org/wiki/ISO_10303
quote:
AP214 and 203 in the area of 3D mechanical design. AP214 took over all of the functionality of the earlier AP203 edition and then extending the capabilities significantly. Now in 2007 the second edition of AP203 takes over bigger parts of AP214 by adding again new functionality.
I seem to remember that there was actually a bug fixed in the HarmonyWare STEP exporter for color information that was causing NX4 to crash when it read it in, so at least at one point colors were going into STEP files out of MoI but I'm not sure if this has possibly changed with an update of the HarmonyWare libraries.
3468.20
Hi Colin,
I finally generated the MoI file from your OBJ file, unfortunately even zipped up it is over 31MB. I'll see if I can get it smaller to post here.
Regards,
Michael T.
3468.21 In reply to 3468.20
Hi Michael T,
Glad to hear you've managed to do something with the second version.
If you want, maybe the other option might be to send it to me via YouSendIt as it's FREE for up to 100MB?
http://www.yousendit.com/
If that idea appeals to you then just PM me for my contact details.
regards Colin
Show messages:  1-13  14-21
