Offset Problem
All
1-2
3-5
Michael Gibson
9 Apr 2010 (3 of 5)
3462.3
In reply to
3462.1
Or probably in this case you'd want to offset some curves to produce a framework to then build the outer piece with.
Offset or shell can't handle a joined surface offset of this type currently.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
steve (STEVE_HOME)
9 Apr 2010 (4 of 5)
3462.4
Hi s7r83dg3,
If you are just trying to add thickness, then separate the surfaces, then while all the surfaces are still selected, use "Extrude-> direction" and extrude in Z. You can then union the solids created.
- Steve
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Kevin De Smet (KEV_BOY)
11 Apr 2010 (5 of 5)
3462.5
In reply to
3462.4
Interesting approach to thickness, nice to use when normal offsetting goes bad!
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
All
1-2
3-5
