SimLab Composer
 1-6  7-26  27-46  47-66  …  87-106
3455.7
Burr - But is it the integrated render engine that Simlab is speaking of on their website? It looks like they may have licensed it from Bunk or Luxion..
3455.8 In reply to 3455.7
Hey Grendel,
I think he is showing an outputed 3dpdf to keyshot. So, built scene in the other app, then brought scene to keyshot through the adobe 3dpdf...
I suppose I should just let ralf answer!! :O
3455.9
Hi guys,
I use SimLab Composer trial for 5 hours.
Yes on this computer are also HyperShot, KeyShot , HyperMove...
But I think SimLab Composer "brings" advanced/add. materials.
Size: 158.3 KB, Downloaded: 159 times, Dimensions: 1124x288px
Size: 434.6 KB, Downloaded: 321 times, Dimensions: 1457x981px
3455.10
I think it is not a secret ;)
Therefore,.... two licenses ordered in the last minutes. :)
Size: 103.7 KB, Downloaded: 235 times, Dimensions: 854x600px
3455.11 In reply to 3455.9
Hi Ralf & Burr, so I see what Grendel is asking about.
So note on this page here:
http://www.simlab-soft.com/3d-products/simlab-composer-screenshots.aspx
Which mentions:
    "Simlab Composer contains state-of-the-art, fast, global illumination renderer"
And also note the ring and vehicles on the bottom of that page, they look a lot like HyperShot/KeyShot type output.
On top of that, on this page here:
http://www.simlab-soft.com/3d-products/simlab-composer-whats-new.aspx
    "Version 2.0 adds new exporters including FBX, STL, and KeyShot (bip) "
So that's very interesting that it exports to KeyShot .bip format - I was looking into that myself for a while and it seemed at that time there was not really any documentation for .bip format available, instead it was easiest to write it by using the Luxion libraries directly.
So all of that seems to imply that SimLab contains a licensed version of the Luxion engine as its new render engine.
Ralf, you are really familiar with HyperShot/KeyShot, right? Are you able to get the same kind of render results directly inside of SimLab Composer ?
3455.12 In reply to 3455.10
Hi Ralf, so your latest post there certainly seems to indicate that the Simlab renderer is the Luxion render engine.
That may be interesting, because that's a lot less expensive than KeyShot.
That may be temporary though, from here:
http://www.simlab-soft.com/3d-products/simlab-composer-licensing.aspx
    "The limited time, introductory price offer of a single commercial license is $149."
Ralf do you notice any big differences between rendering in Simlab versus HyperShot/KeyShot ? Like are the materials different, does Simlab not come with HDRI environments while KeyShot does, stuff like that.
3455.13
All my screenshot`s are inside of SimLab Composer.
Please take a look "SimLab Render Settings":
Size: 132.5 KB, Downloaded: 225 times, Dimensions: 948x826px
Size: 142.2 KB, Downloaded: 189 times, Dimensions: 964x844px
Size: 57.3 KB, Downloaded: 174 times, Dimensions: 1266x415px
3455.14 In reply to 3455.13
Hi Ralf, does the renderer feel generally similar in operation to KeyShot to you?
Any there any major differences or things missing as compared to KeyShot?
3455.15
I just received a reply from their support:
"Yes, the render engine is close to HyperShot/KeyShot, this is an accurate statement.
SimLab Composer does not include a real time ray tracing which gives you instant feedback, but other than that you should get very close rendering quality.
There is no resolution limit to the final image.
Output images are saved as jpeg.
I think the best thing for you to do is to take SimLab Composer to a test, download the trial and request a trial license. As you are familiar with HyperShot/KeyShot it should be easy for you to make such a test."
So I will be getting the trial because as you say Michael $149 is cheap for the unlimited resolution. I do wish their was an output format for images that carried an alpha channel though tiff or psd.
3455.16 In reply to 3455.1
Thanks Ralf, excellent find!
Will check out.
3455.17 In reply to 3455.16
It does look promising. I loaded it and it crashes on "run as demo (save disabled)". I requested an eval license hoping it is just a bug in the licensing Utility for disabled save option. Waiting for that from Amman.
Anybody else loading it up I would appreciate feedback. The forum site for simlabs is pretty non-existant with 2 or 3 posts from the development team.
Anyway.....
3455.18 In reply to 3455.15
Hello all,
i buyed this software and make some test...
i export the z1000 cockpit from moi in different ways:
1. the 3dm import of moi models (export as 3dm) doesnĀ“t work for me...
look at the image... the hierachie is lost too...
2. the step import works very well, but the hierachie is a bit lost... every named group in moi splits up in single objects with the groupname
3. the obj import doesnĀ“t work... there is only a single line (?) visible... but the hierachie is like in moi... that would be cool... but... no objects visible.
iĀ“m gonna contact the simlab guys for this...
the 3d pdf export is very cool and works very well with the step model... and thats the reason why i needed this software:-)
the render quality and speed is not bad..i like it... the use of any hdr image is possible.. but no alpha output.. just "simple" jpgs...
(there is a "alphamask" button in rmb renderview...but it doesnĀ“t work),
maybe usefull informations
best regards,
tijai
3455.19 In reply to 3455.18
tijai,
With the obj export from MoI, did you try some of the other options like "No n-gons/no weld/Triangles only"?
3455.20 In reply to 3455.19
tijai,
ALso, how about a pdf of the part? can you post it without giving away your model?
3455.21 In reply to 3455.18
Hi tijai, the renderings look nice!
Like Burr mentions, for OBJ export, try setting "Output: Triangles only" and also uncheck "Weld vertices along edges" when exporting from MoI and see if that transfers better.
3455.22 In reply to 3455.21
hello
i have to correct my last post...
i donĀ“t know why, but i restart SimLab and the obj import now works perfect...
no more "just a line"... it works and the hierachie is like in MoI... thats very good!!
sorry for the "bug!" shouting..
attached a simple 3d pdf of an moi-obj
works cool
3455.23
I have just been having a look. The 3DM import is a no-go. The obj import is OK if the obj exported from MOI is with quads/tris (well, up to now)
3455.24
It does look like the Luxion render engine, I found their 3dm to obj converter is not very strong and that's what you get, the sliver effect all the time.
Obj import should be fine, don't bother with quads/tris just use triangles option in MoI because the Luxion converter will just split the quads into triangles anyway.
Step should work well, iges is hit and miss.
Looks like I'll have to download the demo and have a play seeing it's only US$149 with no res restriction, it'll better value than the 800X400 limit I have now with Hypershot/Keyshot.
Thanks tijai, the PDF looks great!
Can anyone who is familiar with Keyshot / Hypershot say for sure what the render features & differences are? Real time window snapshots or just full renders? Same material library?
Even if it has some restrictions, that's a very good price.
I like the 3D PDF. I'll have to see if I can integrate a 3D PDF into a web site for product views.
Ed
3455.26 In reply to 3455.25
As an update to my crashing post, I hit the breakpoint of it and it was crashing on my ati stuff. I enabled tripple buffering in the opengl settings and the program launched! I disabled the tripple buffering and now it runs.... Demo-ing it and will probably by it also for the 3d pdf output!
Thanks ralf.
Also, on another computer, antivirus is reporting the installer as suspect? I wonder if this is the licensing stuff doing "machine reading" at launch of the installer?
Show messages:  1-6  7-26  27-46  47-66  67-86  87-106
