BOAT RADIO
All  1-8  9-16
344.9 In reply to 344.1
Hello:
I congratulate you for your work of little time. I discharge him it has programmed for 2 days and I was made very good.
A question. Be rotted to trace images of BMP like in Rhino?
or to attract curved and but options.
Best regards
344.10 In reply to 344.9
Hi Juan, thanks, I'm glad you like it!
For tracing images, use the View / Image command:
There will be several options in the upper-right, including an "Add" button, use that to add images in.
344.11 In reply to 344.8
I think I've got this problem of duplicated surfaces fixed for the next beta.
It would happen if you joined 2 objects where already-joined edges were touching (as in the 2 adjacent cubes example above).
This would create a situation where more than 2 surfaces were joined together at an edge, which confused some other things later on which result in duplicated surfaces.
Join has been improved in the next beta so that it only tries to join open, unattached edges to other unattached edges so it won't end up creating this type of messed-up object.
344.12 In reply to 344.11
Michael ! you're the one !
I can't wait t try this new beta, do you think it will be availaible soon ?
I can't really tell what happened on my object regarding duplicated surfaces. I will try to be more precise the next time I will report you a "bug".
Thank you again for your work !!
(Are you alone to develop such a program ? )
344.13 In reply to 344.12
It looks like not until next week sometime. Just a few more things to finish up.
You're welcome!
Yup, it's just me! I do license a library for many geometry functions from a different company though, for handling stuff like the booleans and fillets.
344.14 In reply to 344.10
Hi Michael:
Very good advice thank you for your help
I can achieve important advances with their cooperation, this it is a place very
good, I hope they continue this way.
Best regards
344.15 In reply to 344.13
hi Michael , thank you again for your answer
because it looks like you answer every questions !! I have 2 new ones for you ;o) :
1- will release 1.0 have a "layer manager" ?
2- How much will you charge for this cute and effective modeler ?
regards
MrGAG
344.16 In reply to 344.15
Hi Guillaume,
No, it doesn't look like it. I expect to work on this more towards the middle of this year after v1.0 has been released.
It hasn't been completely determined yet, but it should be around a couple of hundred dollars.
Show messages: All  1-8  9-16
