BOAT RADIO
All  1  2-16
344.2
Nice Model. And welcome to the forums and Moi.
Cool try!
Added to The Special Thread Gallery :)
344.4 In reply to 344.1
Hi Guillaume, great job!
> I am not really comfortable with nurbs modeling, but MOI made me change !!
Great! :) What you will probably find is that some types of object will work great with NURBS modeling, and some types of models will work better with polygons/sub-d.
So it is nice to have more than one tool available to you since different ones will have different strengths.
Certainly that radio is a great example of something that works particularly well with NURBS!
344.5 In reply to 344.4
Hi Michael !
I tried MOI with a pen tablet this week end and it's amazing how handy it can be !!
I bet it must be a huge developement work to do so !! bravo to you !!
I have just a question about some "copied" surfaces :
within radio object you saw, I have multiple double surfaces, which is crap because I have to check them one by one to "purge" my object. But I just don't understand how these double (sometimes triple) surfaces came through. Are there tools that copies surfaces by default or something like that ?
please apologize my english this morning ....
MrGAG
344.6
If you have a object selected and hold down control and drag your mouse left button it will create a copy of the object. Sometimes when I start going fast I'll hit control instead of alt for moving around and do this by mistake. Maybe that's what happened.
344.7 In reply to 344.6
thank you, I didn't know that ....
maybe you could help on this to : I have just spent half an hour removing double surfaces on my object to be able to propely join surfaces, which I did well, but 5 mn later I saw that my surfaces were not joined anymore !!! it's the third time it happens on the same object
does somedy have a clue about this ?
344.8 In reply to 344.7
Hi Guillaume, I think that this happens (both doubled surfaces and unjoined pieces) if you try to join together 2 objects where the objects share a common face.
For example these 2 cubes:
If I were to move those 2 cubes together and then do a "join" on them, I think that is the type of situation that is causing this problem.
I should be able to fix this up to work better, but in the meantime you should only join pieces that have open edges. Like for the cubes for instance, I would delete the common face (on both cubes) before trying to join them together.
Do you think this thing (join with common overlapping faces) might be what you ran into?
If not, then there is some other problem that I would to track down, please let me know if you figure out which operation is causing it.
344.9 In reply to 344.1
Hello:
I congratulate you for your work of little time. I discharge him it has programmed for 2 days and I was made very good.
A question. Be rotted to trace images of BMP like in Rhino?
or to attract curved and but options.
Best regards
344.10 In reply to 344.9
Hi Juan, thanks, I'm glad you like it!
For tracing images, use the View / Image command:
There will be several options in the upper-right, including an "Add" button, use that to add images in.
344.11 In reply to 344.8
I think I've got this problem of duplicated surfaces fixed for the next beta.
It would happen if you joined 2 objects where already-joined edges were touching (as in the 2 adjacent cubes example above).
This would create a situation where more than 2 surfaces were joined together at an edge, which confused some other things later on which result in duplicated surfaces.
Join has been improved in the next beta so that it only tries to join open, unattached edges to other unattached edges so it won't end up creating this type of messed-up object.
344.12 In reply to 344.11
Michael ! you're the one !
I can't wait t try this new beta, do you think it will be availaible soon ?
I can't really tell what happened on my object regarding duplicated surfaces. I will try to be more precise the next time I will report you a "bug".
Thank you again for your work !!
(Are you alone to develop such a program ? )
344.13 In reply to 344.12
It looks like not until next week sometime. Just a few more things to finish up.
You're welcome!
Yup, it's just me! I do license a library for many geometry functions from a different company though, for handling stuff like the booleans and fillets.
344.14 In reply to 344.10
Hi Michael:
Very good advice thank you for your help
I can achieve important advances with their cooperation, this it is a place very
good, I hope they continue this way.
Best regards
344.15 In reply to 344.13
hi Michael , thank you again for your answer
because it looks like you answer every questions !! I have 2 new ones for you ;o) :
1- will release 1.0 have a "layer manager" ?
2- How much will you charge for this cute and effective modeler ?
regards
MrGAG
344.16 In reply to 344.15
Hi Guillaume,
No, it doesn't look like it. I expect to work on this more towards the middle of this year after v1.0 has been released.
It hasn't been completely determined yet, but it should be around a couple of hundred dollars.
Show messages: All  1  2-16
