Spiral
All  1  2-6
3435.2 In reply to 3435.1
3435.3 In reply to 3435.1
Hi d3,
> when can we have option for creating spiral?
You can have it now! :)
For that, use the command under Draw curve > More > Helix:
There are various options within the command to control it - the default is to place 2 axis points and you will get a helix that is shaped like a cylinder.
If you want something that is spiraled like the shape of a cone instead of a cylinder, enable the "Tapered" checkbox option and that will let you pick a second radius for the end of the axis so that it is sloped.
If you want a completely flat 2D spiral, then push the "Flat spiral" button that shows up after the first point has been placed.
Some more description of it in the help file here:
http://moi3d.com/1.0/docs/moi_command_reference2.htm#helix
3435.4 In reply to 3435.1
Hi d3, or if you need some really specific kind of proportioned spiral like a logarithmic spiral instead of a regular linear one, then one of the techniques in the thread that Pilou posted above could be useful.
3435.5 In reply to 3435.4
Sorry, I didn`t found that option, need to
open my eyes when searching something.
-d3-
3435.6 In reply to 3435.5
maybe this can help you
Menu Draw Curve / Helix
At the end you can all flat with the box edit frame ;)
Show messages: All  1  2-6
