Blend curve on surface.
All  1-2  3-5
3433.3
Couldn't you just do the blend from both curves then project the result onto the surface? Looks like it would work for that example.
Mind you, I'm a noob here so maybe not.
3433.4 In reply to 3433.3
Hi roj, yup I think that for a case like that a projection of the regular curve/curve blend would work.
If the surface has more variation in it over the area being blended, then that may be problematic though.
Another possibility is if you can model a surface that has the general shaping that you want from the blend then you could produce surface/surface intersection curves by using the Construct > Curve > Isect command.
3433.5
Thanks Michael,
The example, as mentioned isn't a problem It was just to illustrate what I meant.
It would be useful for constructing surface to surface continuity, but if you are working on the blend function in V3 then we'll have to wait and see what goodies come from that.
Show messages: All  1-2  3-5
