Hi Janne, a corner point is a place where the piece of the curve before the point will come to a sharp end at that point.
But on the very first point pick, there is no "curve before the point yet", because on the first point there is no existing curve yet, so therefore a corner point setting does not apply there.
If you want to make a closed curve that is sharp at the close point, then set the very last point you pick as a corner point and it will do that.
Also there is a shortcut where you can hold down the Ctrl key while clicking as another way to set a corner point.
