alternate scene shading option?
All  1-4  5-8
3427.5 In reply to 3427.1
Hi tomot, all you really have to do is install and use the v2 beta instead of the old v1 version which it looks like you are currently using.
You can get the v2 beta from here: http://moi3d.com/beta.htm
The v2 beta has a completely different lighting engine enabled on it by default which gives a lot more illumination in different directions onto the model and doesn't leave such dark areas as you would find in v1.
There are different options that you can control on it (like manually tune the brightness levels and tweak the look to have highlights or a metallic look or also switch between some different light setups), but you should not likely need to fiddle with them, just the standard defaults with the new lighting engine should solve your particular problem.
If you do want to tweak the options, check out this previous post that shows where they are in v2:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3348.3
Also check out here for some screenshots of the new v2 lighting system in action:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2843.1
That's just one of the many things that are improved in v2...
There's a list of all the new stuff in v2 gathered here:
http://kyticka.webzdarma.cz/3d/moi/doc/V2releasenotes.html
3427.6 In reply to 3427.5
Hi Micheal:
I'm a "customer" by definition, but only a "potential buyer" at this time. Although I'm glad you have addressed that issue.
In the mean time I'll keep struggling with Moi v1
cheers!
3427.7 In reply to 3427.6
Hi tomot, I see - well it won't be much longer before v2 is out and then there will be a v2 trial version.
The software itself is ready for v2 now, I'm just working on updating the documentation.
From v1 to v2 has been about 2 years worth of work so quite a lot of stuff has been improved, including a major overhaul of the lighting system to avoid dark areas just like you were suggesting.
For v1 the best that you can do for this issue is to set up a keyboard shortcut that will toggle the light direction. Then if you have a dark area you can hit that shortcut key which will change the lighting.
To do that in v1, go to Options > Shortcut keys, and add in a new entry. For the "Key" part put in whatever you want to trigger it, like maybe L for lighting. Then for the "Command" part in the second column, paste in the following:
script: /* Toggle light direction */ var dir = moi.view.lightDirection; if ( dir.x == 1 && dir.y == 1 && dir.z == -1 ) { dir.set(-0.5,1,0); } else { dir.set(1,1,-1); } moi.view.lightDirection = dir;
Then when you have a dark area that you want to work in, hit L (or whatever key you picked) and it should shift the lighting around enough so that dark area is now in light.
For v2 it is not necessary to do any of that though.
3427.8 In reply to 3427.7
Hi Micheal:
Thanks for the explanation, I'm quite sure your charming response, will one day win me over, to become a "buyer"
cheers, and all the best!
Show messages: All  1-4  5-8
