Shelling problem
All  1-3  4-14
3424.4 In reply to 3424.2
Thanks Michael, I had sort of assumed that was the problem. That probably explains why I can shell the shape if I cut it into smaller and simpler pieces by lopping off the heavily curved bits. I will probably try something along those lines.
Dan
3424.5 In reply to 3424.4
Hi Dan, yeah cutting off the curvy bits makes for a more simple structure with fewer surfaces and edges in it.
I've done some surgery and reconstruction on your object and attached the result 3DM file here - I basically removed the curved corner pieces and instead moved the control points for the other curves together to make sharp corners and did some rebuilding of the side piece.
This version will now shell up to about 0.1 units, after that the little bottom narrow part will collapse so the shell is limited by the thickness in that bottom area of the model.
After doing a shell of 0.1 units and then cutting away a piece, it looks like this:
Both Shell and Fillet tend to be rather sensitive operations, if you want to use them you kind of need to plan for it a bit and try to get the model set up into a more simplified state (have stuff like a clean edge structure, no little tiny surfaces or fragmented edges, etc..) to give them the best chance.
3424.6 In reply to 3424.5
Thanks for the help Michael, the solid is as you say shellable. I am taking a closer look to see what you did to it.
Incidentally, I find I am switching Object and Straight snap on and off a lot. I toggle Grid snap with the g key and:
script:moi.drawingAids.gridSnap = !moi.drawingAids.gridSnap;
...but replacing gridSnap with objectSnap (a guess on my part) linked to the o doesn't seem to work.
What are the method names I should be calling for Object and Straight snap?
Dan
3424.7 In reply to 3424.6
Hi Dan,
Actually just replacing gridSnap with objectSnap will work, but note that there are 2 places within that little script that you have to replace. If you only replaced one of them instead of both it would not work right so that may be what you ran into.
So for setting up a shortcut key to switch Object snap on or off, use the following:
script: /* Toggle object snap */ moi.drawingAids.objectSnap = !moi.drawingAids.objectSnap;
and to set up one for switching Straight snap on or off use this:
script: /* Toggle straight snap */ moi.drawingAids.straightSnap = !moi.drawingAids.straightSnap;
3424.8 In reply to 3424.7
Duh! Apparently my brain was turned off :-) Many thanks, all is now working as it should.
On an unrelated note I spent many hours in MoI yesterday and I have to say it treated me incredibly gently given my lack of experience. It works, it works well and it works in a way that a beginner can grasp. I keep finding little "surprise and delight" features like rotation. I had been messing around trying to rotate something with the rotate tool and coincidentally I clicked on the rotate widget in the edit frame of the object; a bounding box duly appeared. "Hmm" I thought, "maybe..." and sure enough I could immediately move the centre of rotation and due to the object and straights snaps 2 seconds later the thing was done - easier than the rotate tool by far.
Or remembering that I needed something from a previous version of the drawing and wondering if copy and paste might work. I started another copy of MoI, copied the parts, pasted and they appeared exactly where they should be. Both small things perhaps, but this would all have been very hard work in TurboCAD with my level of competence. I also appreciate the ability to customise things like the number fly-out and other parts of the UI that I didn't like; developers do sometimes get religious about such things and try to force them on users.
My lack of experience in 3D means that I still have problems with some tools (Orient.... ugh!) but overall it amazes me what I have already achieved in MoI. Every 3D novice should start with this software - it's just a no-brainer. The amount I paid on v1 and the upgrade to v2 is money very well spent. I'm looking forward to new features in v3 of course but I will need some time to really make the best use of v2.
Dan
3424.9 In reply to 3424.8
Hi Dan, that was cool that the rotate widget worked well for you! That's what I call "wheel mode" when you click on it and it switches to the relocatable center point version.
You mentioned you were having difficulty with Orient though?
Could you post a model file that has the objects you are trying to orient in it? Then I could try to give you some step-by-step help on it.
3424.10 In reply to 3424.9
Well, in the shell file I posted earlier, I'm attempting to model headlights to attach to the front of that cab shell. So, looking down in top view, I create a 6-inch circle, extrude circle 2 inches or so, then try to orient the resulting 'headlight' to the front of the cab so that the headlight sits perpendicular to the surface. The target surface in this case is curved so it won't be flush but that's not a problem as when the headlight is perpendicular to the surface I can just move it back so that the body of the headlight disappears into the body of the cab.
What I'm having problems with is the "sticking headlight to surface" bit. I assume orient is the right tool to use but I find the different options confusing when I had assumed that the headlight would just magically re-orient itself to the surface of the target solid. Obviously I can rotate the headlight and move it around, I just thought orient would be a shortcut...
Dan
PS re the earlier shelling issue eventually I drew a profile of the cab, offset the curve to form another smaller but otherwise identical curve, extruded the two curves, then copied the outline of the resulting shell at each uncapped end to get a curve the exact shape of the end, then extruded this curve by half an inch to form the side/s of the cab. Seemed easier that way than shelling.
3424.11 In reply to 3424.10
Hi Dan, could you please post a model file with the headlight and the surface you want to place it onto in the file?
That will make it easier for me to show you using your exact model. If I just create something from scratch it may have different proportions, or I may not understand what particular point you want to have as the point directly on the surface or things like that, it is just a lot easier if I can see your model rather than only having you describe it.
The Orient tool should be able to do what you want, possibly the part you may be having difficulty with is the picking of the source orientation frame. That will probably be something you want to have centered inside the headlight, it will be the "base point" that will then become the point that sits directly on the surface during the second phase of the orientation.
There are some other related tools that could possibly be easier for you to use, maybe try this - select your headlight and right-click the Copy button. The right-click there will run the "Copy with origin point" command instead of the regular copy. That lets you pick a point to define the base point of the copy, so pick a point centered inside the headlight which you would like to correspond with sitting directly on the surface.
Then Right-click on the Paste button, that will do a "PastePart" which will paste in the stuff from the clipboard but also let you set their orientation. Now pick a point on the surface and it will orient the headlight to be perpendicular to it. Oh also in this situation it will orient the original Z axis direction to be going along the surface normal, so for this case you want your headlight to be in a "rest" position pointing upwards.
That process with the source and the target done as 2 completely different steps may be easier for you to control. There are also keyboard shortcuts for those, you can use Ctrl+Shift+C for the copy with origin, and Ctrl+Shift+V for the paste with orientation.
The Orient command does the same kind of thing, but with all the steps combined into one command and also allows a full angular orientation of the base frame to be specified instead of only an origin point (with the z axis being implicit in the source direction in that case).
EDITED: 30 Mar 2010 by MICHAEL GIBSON
3424.12 In reply to 3424.11
Lots for me to consider there. In the meantime the exact model, complete with putative headlight, is attached!
Dan
3424.13 In reply to 3424.12
Hi Dan, so to use Orient there are going to be a sequence of 4 clicks.
The clicks are in pairs - the first click will place the orientation widget, and then it waits for you to adjust the rotation so you'll then do a right-click to exit that stage.
So it's going to be like this: Left click, right click, left click, right click.
It's probably those right-clicks that are confusing you - each of those right clicks is actually the same as pushing the "Done" button, if you look in the upper-right area of the window you'll see a prompt that is telling you what MoI is expecting for you to do next, that can help a lot just in general operation to look at that area so that you can get an idea of what is going on right at that step.
So start by selecting your headlight object (you may want to delete or hide the original source curve used to build it to get it out of the way).
Now run Transform > Orient.
The first click will be on the headlight, on the point that you want to relocate to be on the curved surface. Since your headlight is the same on the top or the bottom it doesn't really matter if you pick the top face or the bottom face for this, here I've picked a point in the center of the top face which looks like this:
After you've clicked there you can now adjust the base rotation, but in this case the default rotation is fine so you just want to exit this stage by pushing Done or right-clicking. If you look at the prompt in the upper right area of the window, you'll see it says "Adjust base axis orientation".
So after right-clicking (or pushing Done) you have now defined the base frame for what piece of the object will be placed on to the surface and also what direction on the object will be associated with the perpendicular direction on the surface.
Now comes the part for placing the target location. The prompt will now say "Pick target origin", so now go and click a point on your curved surface like this:
Now you can adjust the rotation if you want but the default is probably fine for you so just right-click or push Done at this point and you will be finished, getting this result:
Here's what it looks like in action:
But again note that there are actually 4 clicks being done there - left click on the headlight, then right-click to accept the orientation, the left-click on the target surface, then right-click to accept the target orientation.
A couple of things to watch out for - you can get messed up by snapping on to wires from the back side of the surface so you may want to turn off the hidden line display which you can do under the View palette with the "Display hidden lines" checkbox. Also similarly watch out for snapping on to the world x or y world axis lines as well. You may want to zoom in a bit on your target area so that you don't have too much of the screen taken up overlapping those axis lines.
Another thing is that picking the points like this will place the object to be kind of skimming along the curved surface and only touching it at a single point. So if you want to boolean the object you may need to push it in a little bit afterwards so that it is submerged a bit instead of only grazing at a point, or you can try to pick one of the orientation points to be sunken down in the one of the objects so that sunken-in point is used as the target .
Hope this helps!
3424.14 In reply to 3424.12
Hi Dan, also maybe a little demo here of what those "adjust axis orientation" steps are actually used for would help a bit.
Because you have a circular shape, it doesn't really matter how it is rotated left or right around the perpendicular. But for other shapes there may be some particular feature of the shape that you want to position.
Like here I use the "adjust orientation" steps to control orienting the tip of this asymmetrical shape.
I position the orientation widget so the base frame is set up with the x axis pointing towards the tip (this is done by dragging on the axis line and releasing the mouse over the spot you want it to point at), and then when placing the target orientation, when manipulating the target x axis it is like manipulating where that tip is pointing towards:
So that's a kind of shape where you may want to have more control over the rotations, that's why there is that second adjustment step for both the base and the target.
If the automatically determined orientation is fine for your case then you just right-click (or push the Done button or push Enter) to accept it instead of tweaking it.
Does that help to make more sense of the whole orientation process?
Also one other note - the reason why you can adjust the "base orientation" is so that you don't necessarily have to rotate the object around to point towards the world x,y,z axis directions before you do the orient. If you use one of the other methods like the "Copy with origin" method I wrote previously, that does not incorporate an adjustable base orientation, that just takes the world (or actually current CPlane) axis directions as the base one.
Show messages: All  1-3  4-14
