Export option for OBJ names needed - object names lost
All  1-5  6-7
3396.6 In reply to 3396.5
Hi Micha,
> at Rhino the object has a name and a layer and opened at
> MoI it lost the object name. Could be nice if a name exist,
> that the name can be keeped.
That is supposed to work, and does work in Rhino v3, for example here is a box I created in Rhino v3 and assigned a name:
Then when opening up the file in MoI, that name is assigned like you want:
If you are seeing different results, can you please post a sample 3DM file that does not work?
3396.7 In reply to 3396.6
I found the reason for the confusion - it's the script for open rhino documents for meshing. I found the function AssignObjectNamesFromStyles();, set it as comment and it works now. Since I found no rhino script for layer keeping I can keep my object names.
Micha
// Set object names to be their Style name + unique number.
var objs = moi.geometryDatabase.getObjects();
var styles = moi.geometryDatabase.getObjectStyles();
for ( var i = 0; i < objs.length; ++i )
var obj = objs.item(i);
var name = styles.item(obj.styleIndex).name + '§' + i;
// Replace all spaces with underscore characters, since spaces don't work as
// object names in OBJ files.
obj.name = name.replace( /\s/g, '§' );
function Convert(FileName)
var gd = moi.geometryDatabase;
// Open the file, set 2nd param to true to suppress any save changes prompt.
gd.open( FileName, true );
moi.view.resetAll();
// Create the output file name by breaking off the file extension and adding 'obj'.
OBJFileName = FileName.substr( 0, FileName.lastIndexOf('.') + 1 ) + 'obj';
// Save out to the output file, passing the option to suppress the UI. You
// add other options separated by semi-colons with no spaces. These
// options are available for controlling the meshing:
// NoUI=true
// Angle=6.0
// Output=ngons | quads | triangles
// MaxLength=
// MaxLengthApplyTo=curved | planes | all
// MinLength=4
// AspectRatio=0.0
// Weld=true
// Display=shadedwithedges | shadednoedges | wireframe
// ExpandedDialog=false
gd.saveAs( OBJFileName, 'Angle=;MinLength=;MaxLength=;AspectRatio=;Weld=true;Output=quads');
// Let's clear out and suppress any save changes prompt again.
gd.fileNew( true );
Convert('d:\\Temp\\#moi.3dm');
moi.exit( true ); // Pass true to suppress save changes prompt.
Visualisation for Designer and Architects | http://www.simulacrum.de
Show messages: All  1-5  6-7
