cannot open directly MOI files
All  1-2  3-9
3393.3 In reply to 3393.1
Hi Rudy, also this mechanism of how Windows figures out which program to launch when you double click on a certain kind of a file in the Windows Explorer shell is often times called "File associations", if you want to try to find some more information about it.
Like for instance here are a couple of articles which may help:
http://support.microsoft.com/kb/307859
http://www.ehow.com/how_2052279_change-file-type-associations-windows.html
3393.4 In reply to 3393.3
But it may possibly confuse Windows if you have a file association targeting a program that is often not accessible, like on a USB drive that you are removing all the time.
If you want to open files by double-clicking on them in the Windows Explorer, you'll probably want to have MoI installed to your hard drive under c:\Program Files rather than on something that is being removed often.
Another way you can open files from Windows Explorer without having a file association set up is to use Drag and Drop - that's where you launch MoI first and instead of double-clicking or using "Open with" you instead drag the file from the Windows Explorer and let it go on top of the MoI window.
3393.5 In reply to 3393.4
Hello Michael,
I have fixed it.
Actually, it is not the flash drive the problem (to me, if I may...). I actually istalled the new Beta last night on my hard drive, and tonight excited about the new laptop, I downloaded on the flash drive.
I have noticed again a while back when I have installed another Beta of v2, back in september.
When I install the new Beta, somehow it override the MOI v1...meaning, whenever I open a 3dm file, it opens in the new beta.
Anyway...not sure what I want to say.....
I uninstall the new Beta Feb21, and installed it again.
Then (see jpg) I saw what I needed to see (circled in red).
then I've choosen the MOI application, check "alyas open with this program" and back to reality again.
Anyway, now it is OK.
Before uninstalling, I did chose program (as you said in your answer), it opened in C//program files,, when I go to MOI v1 and even MOI v2 Beta, go inside the folder, and click the icon, could not trasport the MOI 3d modeling/CAD application icon as list of programs....
anyway, now it is OK.
when it is it the official V2 release?
Thank you Michaeld as usual.
Really I love MOI!
Best regards,
Rudy
Size: 70.5 KB, Downloaded: 8 times, Dimensions: 478x249px
3393.6 In reply to 3393.5
Hi Rudy,
> in the new beta.
Yeah, that's kind of hard to avoid with Windows file associations - only 1 program can be associated with a particular file extension as the default program to open it when double-clicking on the file, and when you install the new beta, it will set itself to be the current version to open with it.
But you can adjust the file association to whatever you need by using that dialog box that I showed earlier.
Well, I'm working on updating the documentation, that's the only part that I have left to finish before being able to do the final release...
3393.7 In reply to 3393.6
>>>>Well, I'm working on updating the documentation, that's the only part that I have left to finish before being able to do the final release...>>>>>>>
Well, let's see....
A crown of clubs that is organized with named objects, very colorful with surface reporting qualities, has been rebuilt, Has had insecting appied at various points, is providing realtime object properties feedback, with a sillouette applied, and has been dynamically tolerated, and locked from further modifications, and placed and oriented precisley, and scaled and rotated "on the fly", with gem like objects flowing all over it, and some bounds data reflected with actual geometry, with a pinpointed bounds center, and designed with conic quality (Using an RHO value of course), utilizing a mitered base, drawn by specific curve length, Incrementally saved after aligning a bitmap image and scaling it perfectly in the viewport....................
I think I have you covered brother! No worries :o
3393.8 In reply to 3393.7
Hi Burr, that's the "Cliff Notes" (or I guess Burr Notes) condensed version... ;)
But yeah it's been about 2 years worth of new development since v1 so there's definitely a lot of new stuff in there for v2!
V1 seems pretty clunky now, especially right off the bat of using v1 the lighting feels really harsh now and it is tough to work without the edit frame.
3393.9 In reply to 3393.8
Great summary Burr!
It's funny, Monday I've worked on a tablet that had only V1 installed an had no access to my installer.
And it wasn't so bad, in fact much better than anticipated..
The core modeling features and interface was already incredibly efficient!
Marc
Show messages: All  1-2  3-9
