I can't export or "save as"
 1-5  6-24
3382.6 In reply to 3382.5
Michael,
thanks for your help.
I reset Internet Explorer 8, then restarted MOI.
When I saved to LWO and OBJ formats, I first selected the file type drop down, then typed in the full name plus extension on the line above. Hitting save did not bring up the Mesh Options dialog, and the files were not saved.
If you were right about my machine not completing the file name extension, then I would have noticed it elsewhere in my apps. This is the only program of many that saves no file when you hit save.
-Paul
3382.7 In reply to 3382.6
Hi Paul, can you e-mail me at moi@moi3d.com ?
I will send you back a special test version with some extra debugging stuff enabled in it which will let me know exactly what is being returned from the file open dialog.
MoI looks at the file extension of the returned filename to decide which file type to write, and from the symptoms that you describe it seems like that is what is going wrong for you.
One last thing you may try is to not touch the file type dropdown at all, and to only just type in the file name and file extension only, like type in : part1.lwo without actually changing anything in the dropdown.
There is a little bit of custom code that MoI uses for when you change the dropdown to update the filename, but maybe somehow some other software on your system is interacting with that in some unforseen way.
3382.8 In reply to 3382.6
Hi Paul, so I looked over your screenshots again and I think I see your problem - I didn't notice before but it looks like in your screenshot your geometry that was loaded consists entirely of curves and not any surfaces.
Is that correct?
If so then that's your actual problem - in order to write to a mesh file format like LWO or OBJ, you have to have surface data and not only wireframe curve data in the model.
One way you can test this is to try opening the attached sphere.3dm file and then do a Save As to LWO or OBJ formats - does that seem to work ok?
3382.9 In reply to 3382.4
That's why SKP format did work and bring up the mesh dialog box though - MoI does support writing curves to SKP format which it converts to polylines during the meshing process.
But for LWO or OBJ formats though you need to have surface data which will get converted into polygons, not just curve wireframe data.
So that actually fits more with what you are describing, sorry about going off on a tangent - I should have asked you for an example IGES file that you were having the problem with.
So if that's the case the problem though is that you need to get an IGES file that has surface data in it and not just wireframe curves.
3382.10 In reply to 3382.8
That solved the problem Michael. My object was converted from Solidworks to STL first, then imported to MOI. It came in without surfaces, probably lost during the first conversion. I didn't notice because modo, my main 3d app, often displays just in wire mesh view. I realize curves with out surfaces is a different situation. I was able to save out the Sphere you sent in all the formats with mesh options included.
Thanks, for sticking with me on this and seeing it through. This must be a good forum.
-Paul
3382.11 In reply to 3382.10
Hi Paul, no problem, I'm glad we got to the bottom of it!
Sorry for leading you on a wild goose chase there for a bit.
3382.12 In reply to 3382.11
Here is a follow up question. Why are most of the files I load into MOI coming in as just curves and not surfaces? These files have surfaces in other programs, but come into MOI without them.
Paul
I am saving my surfaced files as igs and 3dm prior to import, but they are just curves when they open in MOI.
EDITED: 16 Mar 2010 by PETERSEN
3382.13 In reply to 3382.12
Hi Paul, could you maybe be a bit more specific? Like which other programs are seeing surfaces and not only curves?
Also can you send me an example file that I can look at? You can either post it here, or if you want to keep the file private, you can e-mail it to me at moi@moi3d.com .
An example file would definitely help me understand what's going on, otherwise it is hard to guess.
Maybe the surfaces have been marked as hidden objects in the IGES file, and you need to unhide them to see them in MoI.
Or with 3DM files, it's possible for some programs to store other kinds of things in the 3DM file that MoI does not read, like polygon mesh objects for example instead of NURBS objects, or block instances instead of regular objects...
3382.14 In reply to 3382.12
Hi Paul, thanks for sending me the file in e-mail.
So your problem is one of the last things I mentioned above - you don't have any NURBS surface data in that 3DM file, you only have polygon mesh objects.
Rhino supports several different kinds of data in 3DM files, things like NURBS, polygon meshes, dimensions & text, spotlights, etc… but MoI is focused only on NURBS modeling and will only read and write NURBS objects from a 3DM file and will not read in polygon mesh data that might be in the file.
But since you have the object as polygon mesh data already, it is actually ready to be imported directly into Modo without trying to bring it into MoI to convert it.
To bring the data into MoI you need to have the original CAD data, which will usually be in either an IGES or STEP file. That will contain the actual original NURBS spline surface data in it instead of a bunch of faceted polygons, and that spline data is what MoI is set up to be able to import.
MoI can _export_ to various mesh formats, at which time it will break the smooth spline surfaces down into polygonal facets to store as a polygon mesh, which you can then load into a polygon modeling program.
Typically you will want to do the mesh conversion in MoI instead of in the original CAD program itself, because MoI has a much better process for doing that part.
So you'll probably want to go back to whoever is sending you these files, and ask them to send you the original CAD data (preferably in both IGES and STEP formats) and not to send you only already triangulated polygon mesh data.
3382.15 In reply to 3382.14
Sounds like you should pop up a warning or error dialog, Michael when you try to export to a polygon format without there being any surface data available to mesh?
-Will
3382.16 In reply to 3382.15
Hi Will, yeah that's on my "todo" list to put up an error message for this situation when there were only mesh objects in the file so that nothing was in the file that could be used by MoI.
I do kind of hate those "in your face" messages though, so I've been trying to think if there would be a better way to display these kinds of errors.
3382.17 In reply to 3382.16
Michael,
Can you "know that one is in it" and have some kind of "Reference object" import in? So like the scene browser would have an entry for "Non Editable Mesh object" or something with a "point" at it's bounds center (as opposed to an "Error")
3382.18 In reply to 3382.17
Hi Burr,
Actually that does happen already - when opening a file that contains objects that MoI does not handle, they are actually stored in an internal table so that if you save back out again those objects can be written to the file instead of just lost. That's to try and enable "round tripping" of data in the 3DM file to help avoid data loss.
But there is no visual representation of them.
This would be quite a bit more work to make entries in the scene browser and visual representations of special non-editable objects.
I could certainly do that, but it's the age-old question - what other kinds of actual editing features would you like for me to sacrifice in order to spend time working on special stuff for non-editable "foreign" objects?
It's hard to justify spending much time on an area like this that does not really affect someone who is just modeling inside of MoI.
3382.19 In reply to 3382.18
Not really some kind of representation of the object, more like a "label" instead of an "Error". So since the objects exist and are being stored, and it really isnt an "error", just a label in the Scene browser that states "Stored mesh object" or something like that.
Anyway, it was just a thought.
3382.20 In reply to 3382.19
Hi Burr, so normally in the Scene browser you can use the scene browser to select or hide or show things...
Would you expect for those operations to work on these special objects?
What about deleting them? It could be kind of frustrating if things showed up populating the scene browser but you had no way of actually doing the normal kinds of interactions with them.
I think that would likely open up a big can of worms with a lot of work trickling down from it.
3382.21 In reply to 3382.20
Got it. Short sightedness gets the best of me.
3382.22 In reply to 3382.21
Hi Burr, well don't get me wrong I think it is a good idea.
It's just one of those ideas that is hard for me to implement because there is probably a fair amount of work involved.
3382.23
Well one thing you can do is perhaps limit the drop down format options depending on what's in the scene.
This way there wouldn't be any polygon export formats in the list if there wasn't any surfaces to mesh.
-Will
3382.24 In reply to 3382.23
Hi Will,
Maybe... But that could just push the question off to a different one - then it would be "why isn't the file type I want in the list?", instead of "why didn't anything get written to the file?"
Show messages:  1-5  6-24
