scaling objects
All  1-17  18-19
3377.18
wait, isn't that the same as Shift+Right Click?
3377.19 In reply to 3377.18
Hi Val,
No, there isn't anything special for Shift + Right Click - that's the same as just a regular Right click with nothing added.
Right click is used for a couple of different things - when in a command doing a Right click is a shortcut for pushing the "Done" button. When you're not in a command doing a Right click will repeat the last command.
There is another option for window select though, which is if you hold down just the Ctrl key when doing a window select, that makes it a deselection window rather than a selection window.
Show messages: All  1-17  18-19
