Mesh - Matching resolution along edges
All  1-12  13-17
3365.13 In reply to 3365.11
Sorry for the little delay, I had to think about it, but I would say your solid based idea probably fit the best 'my' workflow.
Probably because I don't use style at an exteme condition, I often make all my material attribution in an other software.
As far as every uv islands have the same ratio (so no stretching/scale difference between every uv's island).
Still have to think about it a little bit too :)
3365.14 In reply to 3365.13
Hi PaQ,
Stretching won't really be possible to totally eliminate if the surfaces themselves compress or squish.
But in relation to one another the way I was thinking would be to do it by surface area of the 3D polygons.
So for instance the corner patch in a filleted box would get a smaller UV area than a larger sized piece.
3365.15 In reply to 3365.14
Yes what's I have in mind in fact, distortion can be fixed with a uv unwarp package.
3365.16 In reply to 3365.12
It's an old workaround used in Rhino to force tesselation where the mesher doesn't find the solution on it's own. So yes, I mean you can try splitting the object then rejoing to make "user-defined" polygonal boundaries...
3365.17
Hi there
T-Splines can sometimes produce the kind of UV continuity you are looking for, but then again that requires Rhino + T-Splines.
T-Splines currently does not use trimmed surfaces, but it places vertex points points into the same plane to give a smooth result.
Think you may find this interesting.
-Fredrik
Size: 109.6 KB, Downloaded: 26 times, Dimensions: 333x266px
Show messages: All  1-12  13-17
