Hello Michael Gibson!
I show here a workflow to use moi exported curves in Hash Animation Master.
It has AI importer and automatically can create patches from curves. But problem is,
that the intersections need to meet to merge at points. Animation Master has curves through points.
Moi has also nice tool Draw Curve -> Through Points, But i need a visualization option next to "Show pts".
Option like: Show Points On Curve.
Also to note to this theme, is that when you use polylines, they come into Animation Master as peaked curves. You can
then adjust IN and OUT magnitude for them to smooth out created patches. But if i could use curve trough points to build
networks, it makes a perfect solution in terms of curve shape construction and model planning.
Also in terms of control, because you can join segments of lines to control how polyline flows.
