Advice please on object placement.
All  1-7  8-10
3350.8 In reply to 3350.7
Hi alex,
> it's so usefull but do you plan to add a real icon for this
> fonction in V2 release?
No, I don't plan to have an icon for this for v2... For v2 you'll need to remember what shortcut key you set up to trigger it.
If you forget, you can go to Options > Shortcut keys to see what shortcut keys you have set up.
I'm not sure exactly what will happen for this command, I think it could be possible to combine its current functionality into the regular ArrayCurve command, I'm going to look into that for v3.
3350.9 In reply to 3350.7
You can also load the plugin gallery tool from Petr's MoI page on the resources tab. This allows you to setup all your commands with icons and names so you can easily see them and remember.
Mine looks like this:
Actually, this is pretty antiquated for me now as you can see with some old commands thast arent really needed in the new V2. You can also make it just text links and pack in a big list of links to launch all your commands. I want to just make my own at some point for fun.
3350.10
Thanks Mickael.
And thanks Burrman, I was not aware of this , I will take a look quickly ;)
alex
Show messages: All  1-7  8-10
