Is it possible to convert surfaces to 'edges' ?
All  1-3  4-5
3335.4 In reply to 3335.3
Hi s7r83dg3, to do one surface out of a volume, select that surface with the "drill-in" selection (you may need to zoom in a bit so you can do the second click on an area on the surface that is not nearby an edge), then use the Edit > Separate command to break that surface away from the main object, then do the steps that I wrote previously on the new separated part.
Also after you do the Ctrl+C to copy the edge curves to the clipboard, you can use Undo to undo the separation part, then use Ctrl+V after you are back to the original object after the undo.
Also if you don't have too many edges you can just select whatever edges you want to copy individually or with a window selection instead of Ctrl+A.
3335.5 In reply to 3335.3
Also another edge selecting method that may be helpful for your case is the new loop selection option that was added in the last beta:
quote:
New Select loop function. Added a new script function to make it possible to set up a keyboard shortcut to select a loop of edges around a trim boundary on a face where at least 2 consecutive edges are already selected. To set it up add a new keyboard shortcut in and for the command put in the following:
script:moi.geometryDatabase.selectLoop();
For an example see here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3112.22
http://moi3d.com/forum/index.php?webtag=MOI&msg=3112.32
Show messages: All  1-3  4-5
