STL to STEP Conversion-Free
All  1  2-11
3332.2 In reply to 3332.1
Hi Colin,
I have had similar success by importing STL files into TurboCAD Professional and saving them as IGES files. I then pull them into MoI, and depending on how you bring it in as IGES settings, I have had them come in as solids as well as individual surfaces. The only issues I usually have with doing this is scaling issues.
Do you have any tips on freeware that can convert OBJ files to STL files? I can't remember if Blender can do this or not.
Let me know.
Michael T.
Michael Tuttle a.k.a. mictu http://www.coroflot.com/fish317537
3332.3
Hi again Colin,
I answered my own question:
I exported an OBJ file from Sculptris and imported it into Blender. I then exported it as an STL file. Then I imported it into TurboCAD Professional v12. (take a breath....) Then I saved it as an IGES file, imported it into MoI with the stitch surfaces option on. The result was a solid in MoI! I am very pleased! See attached JPEG files. It may be the long way around the beach, but it worked for me!
Michael T.
EDITED: 4 Nov 2010 by MICTU_UTCIM
3332.4
Hi Michael T,
Sorry, at this point I haven't had a chance to try the program out.
Being as I'm a Jeweller, STL files are the norm & quite often you'll need to add something around the STL model.
If you already own Rhino then it's not really an issue, as the STL mesh will display OK allowing you to build whatever is needed.
You can then Copy & Paste your various NURBS items from Rhino to MoI & continue from there.
But I much rather do all my work within MoI & STL meshes just can't be imported or displayed.
Being that V2 has the STEP file import, I thought if I can convert from STL to STEP, then I could see the mesh inside of MoI.
Still need to test this idea, but hopefully it'll will work out OK?
Even if your way is a tad "long", it's at least workable for your needs & purpose.
regards Colin
3332.5 In reply to 3332.2
Michael,
Can you expand on your explanation a little on creating and importing the iges files from TurboCad to MOI. Which Iges settings are you tweaking to get a solid from the original .stl.
3332.6 In reply to 3332.5
Actually I open the STL file directly into TurboCAD Pro v12. I then save as an IGES file without tweeking it in TC. I then import the IGES file into MoI with IGES setting to stitch the surfaces together. So far, every time it comes into MoI as a solid body. I am using the latest MoI v2 beta if that helps.
Michael T.
3332.7 In reply to 3332.6
Yep, thanks. I did some more messing around with TC and MOI last night to move the STL into MOI and got it to work. The problem that I was having was a lack of patience. With the IGES files that TC created, it took MOI over an hour to import it into the drawing. It didn't seem like a big model but it turns out to be pretty large, created a 40M MOI file as a result. Not sur if it is size or lack of processor power that makes it take so long, probably both.
If any one knows a way to speed it up........ Otherwise I can just learn to live with it.
3332.8 In reply to 3332.7
In V2 you can use the scene browser to hide edges. When converting poly to nurbs, all those little facets have nurbs edges now. It would be the equivelent of drawing 600,000 lines with MoI then surfacing each polygon.
3332.9 In reply to 3332.7
Hi bmabam, the problem is that NURBS solids are designed to be made up of large smooth surface sheets, and not a zillion little facets that are arranged to simulate a smooth surface which is what you are ending up creating with this method.
Each surface in a NURBS model has some more overhead to it than each polygon in a polygon mesh model. That's because of various things like trim curves being tracked separately from the underlying surface, and each trim curve has both a UV curve to it as well as a 3D curve.
When used as intended for having broad smooth surfaces, that extra overhead is not significant and in fact the data size of a NURBS solid made up of proper smooth surfaces will usually be a lot less than a polygon mesh equivalent, with the NURBS solid also being a lot more accurate as well. For example a NURBS sphere made up of 1 sphere surface is a lot less in data size then a polygon mesh that is arranged to simulate a sphere.
But I can't recommend this kind of an approach where you're ending up with a single little tiny plane surface in the NURBS solid for every single polygon in the polygon mesh. That will only work very well if you have a pretty simple polygon mesh like less than 2000 faces, or if the polygons actually describe the model well like if you have all boxes or something that is actually supposed to be made up of triangles like maybe a gemstone.
What you probably have is something that is actually supposed to be a smooth surface, but instead you have 100,000 little facets that are arranged in such a way to try and emulate a smooth surface. That is not a good kind of thing to have as NURBS.
Usually for such things to get a good result you need to reverse engineer broader smooth surfaces from the polygon mesh data. There is some specialized software that can do stuff like that, check out this previous post for some links to some of those reverse engineering programs:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2469.3
3332.10 In reply to 3332.9
Thanks for the explanations. I understand the problem but for those of use that just do this for a hobby and the cash flow is always on the negative side, justifying a the money it takes to buy some of the software packages that it takes to do this kind of thing is pretty hard to justify. If there is a way to do these things on some type of limited basis like using TC and importing the IGES file, that will have to work for now. It takes a while to import the stl and it takes a while each time you do something with it. I can live with that for now and hope that someone will come along with the neet little free converter that has a fix it button.
Now for a real question. Is there an limit on the size of the stl file or # of facets in the stl file that can be imported or is simply a matter of the bigger it gets, the slower thinigs happen.
Also, a request. It would be nice if you would use more progress bars. For these operations, that take some time like import and export, I've sat more than once wondering if I should kill the program because it hit a dead end. To your credit, it always comes back when the operation is complete. A visual that things are still running is always helpful.
3332.11 In reply to 3332.10
Hi bmabam,
There isn't any one specific limit, it's more of the second thing you mention there where if you have a whole lot of polygons it will become heavier and heavier in data size and get slower.
I'd think you'd want to stick with something around 2000 faces or so.
It's just a not a good method to use though for heavier meshes, objects structured like that are just a very bad fit with the way NURBS work.
Yup, in v3 I'm planning on working on this for importing.
For v2 there was a big step forward for export, there is a progress bar shown during the mesh generation stage now when exporting to a mesh file format.
Show messages: All  1  2-11
