where are prefs saved under windows 7
3315.1
I am migrating from xp to windows 7.
Where are the proogram prefs saved in windows 7? I would like to use the prefs I had under XP for moi.
3315.2 In reply to 3315.1
Hi okapi, under Windows Vista or Windows 7, the moi.ini settings file is saved here:
C:\Users\ [your user name] \AppData\Roaming\Moi\moi.ini
Under XP it is stored here:
C:\Documents and Settings\ [your user name] \Application Data\Moi\moi.ini
If you copy the moi.ini file over to your new machine you will then get the same settings you had previously.
3315.3
thanks a lot Michael
