MoI as "the Visio of 3D?" Rendering advice please
 1-18  19-38  39-45
3310.39
Hi Dan,
Although not exactly what you're after as a "Render program", figured I'd do a very quick render for you using my V-Ray for Rhino.
The model I've used is the one that BurrMan had posted earlier on within this thread.
regards Colin
3310.40 In reply to 3310.39
Dan
I used a lot of arrays/revolves etc!
After, first, a lot of mind twisting exercises and experiments!
A very mind broadening experiment!
Brian
ps--please!---dont ask me to repeat it!!!!! (I was so surprised when a result worked so much that I forgot what I did in detail!)
3310.41
Just couldn't resist putting in my 2 cents on alternative means of constructing some of the geometry in this thread using MoI.
Here's a version of a lattice created procedurally:
And here is the MoI script used to generate it:
Although it might be a bit of a challenge to create such as script initially, the advantage is that it is very easy to tweak things once you have it working. Here are two more variations of the original, with the only difference being that the first line of the script was changed to "n = 13;" and "n = 25;" respectively:
This particular script also has support for changing the radius of each sphere type, the radius of the connecting rods, the distance between the lattice points, and the style colors for each of the different elements, in addition to the overall size of the lattice.
BTW, for the n = 25 case, it took about 13 seconds to run the script to create the lattice. But at this point we are definitely getting outside of MoI's normal "comfort zone". Zooming and rotating the model to take the screen shot was initially extremely sluggish (nudge the mouse, then wait 3 or 4 seconds for the screen to update). I tried setting the Meshing angle to a much higher value and that seemed to help quite a bit. I could actually rotate and zoom the scene much more normally...
- Dave Morrill
3310.42 In reply to 3310.41
Sorry I don't remmember how launch this sort of script concretly?
With a normal shortcut? (put the text code in the second column? or inside another script ?)...
3310.43 In reply to 3310.42
Sorry, forgot to mention that the script uses an unreleased procedural library, so you can't run it at the moment. Maybe someday. It was meant more as an example of using the MoI programming API rather than something you could try yourself at home...
- Dave Morrill
3310.44 In reply to 3310.43
Michael, if you could just finalise the API Dave used, polish it to a high sheen, add a nice little front end, document the whole thing in detail and release in time the weekend, I'd be grateful.
Dan
3310.45
Dave!
I was wondering about the procedural script just the other day...
Release one :)
It'll be so handy!!
Show messages:  1-18  19-38  39-45
