OT: making jewerly from models
3308.1
Hellos,
since we have some jewelers here (whose posts got me down this road in the first place) I'd like to ask if anyone can recommend a company/shop who will create metal jewelry for me in the same fashion that 3D models can be printed, i.e.
1) I model the stuff in Moi (or some other program if necessary)
2) upload the model
3) get finished piece(s) shipped to me
We are talking individual items or low volume, not mass producing. I've read a lot and watched videos about lost wax casting, metals, molds and whatnot, but I'm not going to do that myself, I'll let the pros handle the fumes :-)
3308.2 In reply to 3308.1
Hi candide,
I use Moi and send the stl files to http://www.best-cast.com/ . They are great to work with and very fast.
They do a build of a plastic model for about $80. Rubber molds run about $25.
Best regards
Tom
3308.3
I have seen www.shapeways.com at last siggraph.
3308.4
Tom - thanks, I've sent them an email about whether they handle international orders (wasn't obvious from their website)
litium - I know Shapeways prints (plastic) 3D models, not sure they do custom metal casting
3308.5 In reply to 3308.4
Shapeways also does polished stainless steel :)
cheers,
eric
EDITED: 10 Feb 2010 by ERICCLOUGH
3308.6 In reply to 3308.1
Hi Candide,
I got your PM back at start of December last year & tried to reply, but obviously you've not set your Private Message Options to "receive".
Been waiting for you to post again so I could reply.
Here's the basics of that PM from December.
Hi Candide,
The basic process of turning a wax model into a metal version is called "Lost Wax Casting".
Here's some links for you.
http://en.wikipedia.org/wiki/Lost-wax_casting
http://www.google.com.au/search?hl=en&client=firefox-a&rls=org.mozilla%3Aen-GB%3Aofficial&hs=s6Y&q=lost+wax+casting+jewelry&btnG=Search&meta=&aq=f&oq=
http://www.ganoksin.com/orchid/archive/index.htm
Obviously the limit to details will be mostly dependent on what the finished model size is to be...
...typically for a milled wax this will be dependent on the finest Cutter used & the actual mill's mechanical resolution...0.025mm on average.
Your best option would be to do a Google Search for a Jeweller offering CAD/CAM within your area.
This way you can physically see what their work quality is like with regards to models they've produced & if they're going to be helpful with explaining what's needed from you with regards the model.
Thicknesses, the depth of model sections & surfaces will all play a crucial part in how well your "virtual model" will transform into a "real model"
You maybe required to supply them with either the 3DM file or the STL file...typically for milling purposes, just an STL file is used & needed.
Hope all of this info is of help.
regards Colin
EDITED: 10 Feb 2010 by COLIN
3308.7
Thanks Colin! It might have been some sort of spam protection built into the forum software as I was a brand new member back then. My PMs work now.
3308.8
http://www.rjmrp.com/main/
MOST excellent company.
C.
