Window selection
All  1-2  3-20
329.3 In reply to 329.2
Actually, there is already a certain type of selection filter in MoI. I hope you have noticed the drill-in mode, jonah.
Quotation: "You can use drill-in selection to select an edge or face of a solid. The first click on a solid will select the solid as a whole object. A second click on it will drill-in to select an edge or face of the solid. Once an initial drill-in selection is made, further clicks or area selects will target the same type of sub-object. For instance, if you drill-in to select an edge you can then do area selections which will only target other edges."
It's strange, but I have got accustomed very quickly that I needn't press the Shift or Ctrl key to adding/removing object from selection.
Petr
329.4 In reply to 329.1
Hi Petr, yes this is a problem area. It's especially a problem when you are zoomed in very close to an object so that there are surfaces filling up the entire screen. This situation also causes another problem which is that it becomes difficult to click in an empty area to clear the selection which is frequently needed - but for this one there is a solution to use Select/Desel all. I had thought for a while about putting in a Select/Window button, which you could use to trigger an explicit window selection like you are asking about. But after thinking about it for a while it seemed just obscure enough that it didn't seem to deserve its own button. But maybe it should have its own button.... After all you don't frequently need Deselect all neither, just really for this one situation again.... But I worry a lot about adding buttons... ;)
The click and pause is a good idea, but I probably won't be able to experiment with that until V1 is finished.
A modifier key would be pretty easy to do, but I can't use alt since alt+left drag is currently an alternative way to do viewport rotation which is friendly for users of other 3d apps. Shift+drag is currently open, I could put it there... But it is not bad to have modifiers left open for future expansion though too.
I have some other thoughts for doing filtering for v2 - the basic plan was to have a Filter: dropdown within the select tab on the side pane. By default it would be "auto" which would be the drill-in selection as it currently works. But you could switch the filter mode to Solids, Faces, Edges, Curves, etc... This would then help you in some difficult selections since it would ignore all other object types and only target the specified type when you clicked. In addition you could select all of those types of objects by just doing a "Select all" with the appropriate filter active. This way it would serve 2 purposes - for clicking and for selecting all of a certain type.
329.5 In reply to 329.2
> I am very often selecting elements which i don't intend to
> select.
Hi Jonah, the selection preview halos are meant to help with these problems.
For example when you move the mouse around, the curve that is currently being targeted for selection will get a yellow "halo" glow around it. Similarly if you are targeting an already selected curve to click on it for deselection, it will get a dark halo around it (as a preview that clicking it will turn it "dark" or unselected).
So if you watch for these graphic indicators, they should give you a preview of what will happen if you clicked right at that spot, which should help reduce errors.
> Or trying to deselect an edge which is behind the face, and then selecting the face by mistake.
In this case, you should be seeing no halo around the edge, and instead the face would light up, before you clicked. So wait until you see the dark halo around the edge before you click in this case and that should help solve this problem.
329.6 In reply to 329.3
I was quite worried about this originally - it is one of the several big experimental areas that went into MoI.
But it gets addictive after a while, and of course it is a key thing for enabling keyboard-free operation.
Now when I go back to a legacy-style application where you have to hold shift, it bothers me. You don't really know how often you have to do it (along with little glances down at the keyboard kind of slightly breaking your rhythm) until you don't have to do it for a while... :)
Luckly it seems as if I have gotten away with all the experimental areas in MoI - so far at least! :)
329.7 In reply to 329.5
i think this is a reflex from using Rhino. I'm not used to waiting for the pre-selecion highlight. So if i want to deselect an edge (but it's not highlighting perhaps due to screen angle) then my instinct is to just click there. But then i've accidentally deselected everything because i've clicked on a face :( Patience is not my strongest personality trait. Maybe i need to slow down a little bit when I'm learning something new :)
jonah
329.8 In reply to 329.3
Of course i know that, do you think i'm living under a rock? :) Actually as explained in my reply to Michael it takes some "unlearning" for me to get used to waiting for pre-selection. In rhino you can select edges through objects even when the current shading mode doesn't show them. So i've gotten used to being a little "gung-ho" with my selection methods. I know it's in there, so i instinctly click it...
Not "Using the keyboard" was not a start intention of Moi ? :)
329.10 In reply to 329.9
Certainly! :) But it is not a guarantee that every single minor feature will never use it!
I think that having some lesser-used or very expert-oriented features only on the keyboard is not so bad. I'll certainly try not to do even that, but one big benefit of having a keyboard feature is that it prevents clutter in the interface, which can also be a big problem.
But it will always be the case that the functionality required for just basic operation will not require the keyboard.
329.11 In reply to 329.7
The other thing that will help with this is making undo work to recover a selection change. I mean if you make a selection mistake and everything gets deselected, just hit undo right then to restore the previous selection.
I've been meaning to do this for a while, maybe I will see if I can crank that out right now!
329.12 In reply to 329.11
sounds like a perfect solution on one hand, if only to revert one step backwards in the selection set. But it might create the need for extra undo steps for many other situations. and since Moi has no feedback for what action is being undone, it may create a problem for someone who intends to undo the last action, but not realize they've only undone the last selection. Maybe they realize 50 steps later that something was not undone properly... So i think this "revert selection" would best be handled in one of two ways:
1) have a seperate undo stack (and seperate command) for selection states. Maybe not the best idea though.
OR
2) limit the undo function to act only on selection states within a running command. Selection state is cleared when the command is cancelled or completed.
jonah
329.13 In reply to 329.12
There is somewhere a little script for That : "hide the invert selection" :)
Very useful, you have not it?
329.14 In reply to 329.13
I haven't made any attempts to use scripts. How does the script "hide the invert selection" apply in this case? We are discussing a way to go back one step in the selection history stack. I don't see the connection of the 2 purposes... ?
329.15 In reply to 329.12
Well, there is graphical feedback - really the vast majority of the time there are pretty obvious changes when you do an undo, and you are usually watching for some specific result.
But yes, this is possibly a problem.
Re: #1 Separate undo stack
This solution I don't think is so good since it involves duplicated UI. And a lot of people just wouldn't find the alternative "undo", it is a lot easier to use when there is just one undo.
Re: #2 - only allow selection undo within commands.
Well, I was definitely planning that it would be cleared when you exited a command - the selection undo action will be a pretty transient thing, it will just store one entry for the last selection and any type of change should clear it away. It is really for use only immediately after you have done a selection.
But I don't think it would be good not to offer it at all if you are not in a command - there are certainly a lot of things where it is natural to build up the selection set before you go into the command, and it is easily possible to get a selection error there as well.
I think I'll just give it a try and see how it works. If it becomes a problem with undoing geometry changes then it can be fine-tuned a bit, perhaps only "large" selection actions such as deselection of many objects could be recorded...
329.16 In reply to 329.14
Right no "connection", just complementarity :)
329.17 In reply to 329.4
I start thinking about removing SelectAll, DeselectAll buttons completely! hmmm.... These are very special-purpose buttons and none of other functions can be linked to them. Maybe they should be attached to the "click and pause menu" or to mouse gestures once mentioned.
....perhaps, it's time, time to call an election and users should vote on "how frequently do you use the SelectAll, DeselectAll buttons"? hehe...
The ResetAll button in the View tab is quite funny as well. It could be shifted to the middle of the screen where the viewport boundaries are crossed - in the shape of a small ball.
....for clicking, for selecting all of a certain type and for area (window) selecting as well, I guess. Perfect!
I have noticed that the buttons in the middle section of a command palette (Edit, View, Select) are quite colourful while the others aren't. Is there any reason for this?
Petr
p.s. I'm in a good mood so I hope you excuse me that I "kick against the pricks"..... hehe..
329.18 In reply to 329.17
Well, the select all can be pretty useful. The problem with the click+pause or mouse gesture is that is very hard for someone to discover it just by messing around with the software. So I would worry about hiding that one away.
I don't think I mentioned it before, but select all also currently pays attention to the implicit drill-in filter.
I mean if you have an object and you select an edge of it, then select all will select all edges of that object.
Hmmm.... Kind of a lump in the middle of the screen? I think I'd have a hard time making that look very nice. I had been thinking about making right-click on any viewport's reset button doing a reset all - I've got that set up now for the next beta.
> reason for this?
Just a coincidence. The commands in the top and bottom sections happened to tend to be easier to represent with more geometric shapes and actual shaded 3d object examples. Those tend to be less colorful. Icons that have a more interpretive graphic stylized symbol are more colorful.
Certainly! Kick away! :)
329.19 In reply to 329.18
Not only all edges of that object, but also all other objects in the scene (ok?)
I will like it. (Although, this spot might be "abused" by you sometime.)
Petr
p.s.: I've inflicted a punishment on myself because of my impudence. I just have to translate the MoI's introductory documentation into my native language. So I say goodbye......
329.20 In reply to 329.19
Yes - this is also consistent with window selection. If you have edges turned on for one object, and you window select it but also include other objects in the window selection, those other objects will also get selected.
I was thinking that clicking and dragging there would eventually allow you to resize the proportions of the split views...
It's a little hard to think about putting something useful at that spot, since it will be gone when you switch from the split view into a single view...
Cool! It's always good when others benefit from your self-imposed punishment!! :) :)
Show messages: All  1-2  3-20
