Boolean issue II
All  1  2-7
3283.2 In reply to 3283.1
Hi Derek, yup the problem is exactly as you suspected - the shape you are using is not a completely sealed solid, it is only an open surface.
The quick way to diagnose this is to just look at the object type indicator here:
That's one of the new features for MoI v2.
That type indicator will show "Solid" when you have a solid selected - in your case it says "Joined srf" to indicate that you have several surfaces joined together but not totally sealed everywhere into a complete solid.
Then to get more specific information you can set up a keyboard shortcut with the script on it from here:
http://kyticka.webzdarma.cz/3d/moi/#SelectNaked
which will highlight "naked" edges - those are edges that are are not joined to another edge, making an opening in your object.
In your object there are quite a few of them:
How was your object created? There seems to be some pieces missing, like the side walls of the hole on the side are just not there.
3283.3 In reply to 3283.1
Hi Derek, was this possibly modeled at a smaller size and then scaled up to its present size?
There are a lot of pieces that just do not fit with each other with a very good tolerance.
For example here:
Those are 2 trimming edges of that surface which are supposed to be touching one another, but you can see there is a significant gap between them.
Similarly the edges of this piece does not line up well with the edges of its surrounding surfaces:
Several of those pieces are probably going to need to be reconstructed to have better accuracy and touch the surrounding geometry more closely.
3283.4 In reply to 3283.1
Do you have any of the original curves used for constructing this model?
If you can post them, it may help me to give some tips on some more robust construction techniques, like trying to build larger surfaces rather than a lot of little slivered pieces or some stuff like that.
Try to build some pieces larger than you need initially, with fillets applied for the rounded edges, then slice away excess material with a boolean, rather than going around trying to fill in one little patch at a time.
3283.5 In reply to 3283.1
Hi Derek, here are some steps that would probably be easier for building a piece like this, working more with solids throughout rather than by going around filling in little patches.
To start with I drew a curve:
Then mirrored it and extruded it out into a solid block:
Now use Fillet to round off all the sharp edges:
Then prepare another curve, I used Construct > Offset to offset the original curve inwards a bit:
Then use Boolean Difference to cut the solid by the offset curve, to make a sharp inside cut, leaving the fillet around the outside to be rounded:
Things can tend to go more simply and quickly by working on a carving out pieces away from a solid like this. Hope this helps,
3283.6
I just love these kinds of posts!
For me, that object type indicator is one of the most important features of v2 - I can tell at a glance if the object I have in hand is not a solid the way I expect it to be!
-Will
3283.7 In reply to 3283.5
Michael,
I really feel appreciated for your quick answer. I fully understood what you say.
I was designing a mobile device case for my own. This is the part of it.
I go to a local CNC club meeting in Portland, OR.
Next time I go there I plan to demonstrate MOI.
Thanks again Michael. I'll probably be back to ask you for technical issue.
Show messages: All  1  2-7
