Buttons disappeared
3277.1
First of all, thank you for extremely nice piece of tool!
I have used it a lot already since 1.0 beta without any complications but now I've run into something I can't get rid of.
Suddenly, DONE and CANCEL buttons are missing from right upper corner for all commands..???
This is a view when I pushed HIDE:
If I select items and then click right mouse button to apply DONE, it just quits command without doing anything..
If I instead of right clicking select HIDE button again, objects are brought to work space as should.
Other commands behave similarly oddly..
Now, I have already tried re-installing twice with cleaning registry with CCleaner in between with reboot.
Still the same..
I have noticed that it has not asked licence key when installing though, so maybe there is still something left in the registry to cause this repeatedly.
Any ideas?
-Sampsa
3277.2 In reply to 3277.1
Hi Sampsa, you can fix that by installing the MoI v1.1 update, which is available from the main web site download page here:
http://moi3d.com/download.htm
It's caused by a problem in Internet Explorer version 8. The missing buttons would have started happening in MoI v1 after you installed IE8 on your machine.
When you run the updater, it will patch your existing MoI 1.0 installation to version 1.1, and version 1.1 will work fine with IE8 installed.
Yes, starting in v2 the license key is also stored in the registry when you enter it, in order to help people who are running in a more restricted environment than usual, where no files are allowed to be written to the hard drive at all.
But there is nothing in the registry causing your problem - it's caused by a change in behavior in IE8. Updating to MoI v1.1 should solve the problem.
MoI barely places any information in the registry at all, just a backup of the license key when it is entered, and some stuff at install time for the Windows shell to associate 3DM files to MoI. That's one reason why it is possible to copy the install folder and your license key file to a USB key and then take it to a different computer and run it directly off of that key without even doing an "install".
EDITED: 30 Jan 2010 by MICHAEL GIBSON
3277.3 In reply to 3277.2
That solved it.. Simpler than I expected.
Thank you!
-Sampsa
