Export obj -> into 3D Studio MAX
All  1-2  3-10
3259.3 In reply to 3259.2
Hi project6,
After much experimentation with this same issue, I agree with PaQ that fbx is your best option, particularly if you do not require styles exported as materials (I believe not yet implemented in MoI's fbx exporter).
May I ask why you are applying mesh smooth in Max? My experience is that MoI exports to fbx with perfect smoothing and I have found Max to be one of just a few apps which imports MoI's meshes with smoothing (vertex normals) intact.
3259.4 In reply to 3259.3
Might be some relevant info here for you: http://moi3d.com/forum/index.php?webtag=MOI&msg=3080.1
3259.5 In reply to 3259.1
Hi project6, that weird "capped hole" result that you show is due to the Max OBJ importer not being able to produce a correct triangulation of those n-gons.
You could submit it to Autodesk as a bug report and hope that they fix up their OBJ importer, but they have not seemed to put any effort in that area for many years now.
But they do put effort into the FBX import, so that is why I added FBX export to MoI v2. If you use FBX format to go into Max, you should get much better results.
Just make sure to get an updated FBX import plugin for Max, which you can download from here:
http://usa.autodesk.com/adsk/servlet/pc/item?siteID=123112&id=10775855
The FBX importer can handle complex n-gons much better than the OBJ importer - it would be nice of course if they could use the same code for both instead of having a bad quality one for the OBJ importer. I don't really know why they do that, you would have to ask Autodesk about that.
Also the OBJ importer does not always seem to be able to import vertex normals. Getting vertex normals imported helps to get a much smoother shading. Vertex normals seem to go through FBX format fine though.
re: Mesh smooth - you should not generally be applying mesh smooth to output from MoI - mesh smooth is something that requires a subdivision friendly topology, most of the time you need to have carefully set up the mesh topology to be prepared for doing that. If you do want to do it, you would probably want to use some re-topologizing tools to produce a more subdivision friendly mesh topology.
But why are you doing mesh smooth at all, is it to try and get a better quality shading?
If you use FBX format where the vertex normals come through ok, you should get a much better quality shaded result directly from the import without any extra steps.
3259.6 In reply to 3259.5
Thanks for your input, I'm using an older version of MoI and .fbx is not availible in the export list.
I'm used to working with .obj since that's what I receive most of the time, so it was a natural choice to try, but then again I have seen a lot of problems with importing .obj so this makes sense.
Again, thanks for the input.
3259.7 In reply to 3259.6
Hi project6, you can download the current v2 beta version from here:
http://moi3d.com/beta.htm
That will then get you a working version for now that has FBX export in it.
Otherwise without FBX it is hard to get the best results, but if you must use OBJ set it to Output: Quads & Triangles instead of Output: N-gons to avoid the worst problems with bad triangulations that was causing holes to get covered up.
Also one other tip if you have to use OBJ - try using the "Divide larger than" option to dice polygons up into smaller more evenly sized pieces, that can help to reduce shading artifacts that happen when the good vertex normals do not go through.
But FBX is much, much better going into Max.
3259.8 In reply to 3259.7
Thanks for the link, I will try the 2.0 beta.
I guess this is a bit off-topic, but I contacted Autodesk about my problem and they do have a converter utility that takes an OBJ input and converts it to FBX. This may be helpful for other people here stuck with OBJ output so I'm posting the links here:
Windows: http://images.autodesk.com/adsk/files/fbx20102_converter_win.exe
Mac: http://images.autodesk.com/adsk/files/fbx20102_converter_mac_enu.pkg.tgz
Linux: http://images.autodesk.com/adsk/files/fbx20102_converter_linux_enu
The reason I'm lingering with OBJ instead of FBX is I have a number of applications in my pipeline that can only output OBJ, and also a lot of my clients use OBJ as it's some form of standard today.
Unfortunately, Autodesk's converter seems to strip Smoothing Groups, but at least it's something. I read that MAX 2010 has better OBJ import module, maybe it's time for an upgrade...
Anyway, back to topic, thanks for your response Michael, at least now my problems regarding MoI have been resolved. :)
3259.9 In reply to 3259.8
I also found that the Autodesk fbx converter discarded the smoothing information. Very frustrating.
My testing of the Max 2010 trial indicated that it does a reasonable job with obj.
My eventual workaround has been to export obj from Moi (I needed styles exported as materials), import obj to Blender using an obsoleted Blender script which Michael kindly modified (necessary because the current Blender script discards the smoothing info!) and finally export to Max from Blender as fbx (Blender's fbx exporter is very good). Note that you shouldn't make any changes within Blender as it seems that doing so results in Blender re-calculating the vertex normals, ruining the smoothing.
Blender script is in this thread...
http://moi3d.com/forum/messages.php?webtag=MOI&msg=3164.1
Mark
http://www.homepages.ihug.com.au/~mabrown/index.html
3259.10
Hi all
>>because the current Blender script discards the smoothing info!<<
Import .obj in Blender with Smooth Group option then Edit ( [F9] ) and
add EdgeSplit modifier to object and deselect the From Edge Angle button.
Show messages: All  1-2  3-10
