Loft and Sweep Shading Problem
 1-7  8-22
3255.8 In reply to 3255.6
Hi PaQ, no problem.
> (probably because I'm a sds hires modeler)
Yeah, the most typical SDS usage tends to generate a lot of quite small evenly sized polygons being used which helps to avoid mach banding.
But also these artifacts are really increased quite a lot by real-time display techniques, which is just focused more on speed than quality.
A full render just does things in a more accurate (and also slower) manner and many things like that will simply disappear at actual render time.
Here's another example with your same file, exported with just angle = 12 from MoI with no extra subdivisions. In MoI the exported mesh looks like this:
Importing that semi-rough mesh into Cinema4D looks like this:
Note that real-time display actually looks even worse than things did in MoI - that's probably because the C4D real-time display is using only per-vertex gouraud shading which increases mach banding artifacts. When I updated the lighting engine in MoI in v2 to use light mapping instead of gouraud shading, it helped to reduce mach banding in MoI's display but not totally eliminate it.
But look what happens when I do an actual full render in C4D :
Poof - those artifacts are just gone... And that's even with long polygons, here is a look at the wireframe in C4D:
So much of the things you are referring to are artifacts in real-time display techniques, that won't actually apply at render time... (as long as you are getting the true vertex normals being used by the render)
The real-time artifacts tend to be more pronounced on long polygons, which you're getting more of with those cone shapes.
If the NURBS surface actually has little undulations and ripples in it, then that's another kind of problem, but that is not what is happening in the case you posted here though...
So I mean to make a long story short, you can just ignore those artifacts you are seeing in this case, they should not really be there when you do your final render.
3255.9 In reply to 3255.7
Hi Burr,
> Is there such a thing as a NURBS Video Card?
No, not for Trimmed NURBS surfaces which are complex to process.
There is some new stuff in the latest generation of Direct3D 11 cards to tessellate spline surfaces on the card, but it can only handle simple untrimmed surfaces, they don't have anything for processing trim curves.
> A video card that renders NURBS on the screen? No translation to poly's.
Well, one method for rendering NURBS "directly" can still actually involve polygons, it just dynamically produces enough polygons until each one is smaller than a pixel on the screen so you can't tell that they are polygons.
Another method is to do raytracing where you shoot out rays from the eye point and do an actual line/surface intersection for each pixel on the screen.
Either one of those involves a heavy amount of computations, so it tends to not be fast enough to do for a real-time viewport display.
3255.10 In reply to 3255.8
[So I mean to make a long story short, you can just ignore those artifacts you are seeing in this case, they should not really be there when you do your final render.]
Well looks like in modo it's an other story :(
I will try to post something about it on modo forum (using your screen proof), but I'm not sure if I have to post it as a bug, or as a feature request :P
EDITED: 3 Feb 2010 by PAQ
3255.11 In reply to 3255.10
Hi PaQ, hmm that is interesting... You have not deleted the normal map or anything like that have you?
Did you do any transforms on the object, or is it rendered directly after import without any kind of editing of the geometry?
Maybe we should make a standardized file for for testing - I took your Loft.3dm file and capped the middle shape, then exported it with Angle = 12 to make the attached ShadeTest.obj
Then here is the result rendered in Cinema4D v10:
3255.12 In reply to 3255.11
Opening the .obj, center the camera, F9 (rendering) ... I didn't edit anything else
3255.13 In reply to 3255.10
And render in C4D10 with no specular looks like this:
3255.14 In reply to 3255.12
Hi PaQ,
Well, looks like mach banding artifacts.
Is there any setting in materials to do full Phong shading?
Maybe it's not doing very careful interpolation of the normal or something like that.
As you can see in the Cinema4D renders, if the vertex normals are treated carefully by the renderer so that each individual pixel ends up getting shaded by a good normal, it makes for nice results even with a pretty rough mesh.
Maybe it is not as common to do that as I had thought though.
3255.15 In reply to 3255.12
Hi PaQ, quick question - can you switch to an orthographic/parallel type camera and then give it a try?
Does the render look different in that case?
3255.16 In reply to 3255.15
There are no shading option available in modo, there is a 'smooting angle option' in degree, to control the surface normal, but the vertex normal channel overwrite this setting anyway.
Same result whatever the camera mode (ortho or perspective)
3255.17 In reply to 3255.16
Hi PaQ, well I guess for now if rendering in Modo you will need to force some dicing of long polygons into smaller pieces to reduce those artifacts.
It seems like it would be a good thing to report to them, because it doesn't really have to be that way, as you can see from the Cinema4D examples.
That kind of mach banding artifact usually happens in Gouraud real-time shading because in that shading method the normals are only evaluated against the full light sources just at the polygon's vertices, and then those colors blended throughout the polygon.
It kind of looks like you're getting that same kind of effect in the full render...
3255.18
I did some testing by building a cone in Modo with approx. same vert. count, and did one with double the verts. and it was
pretty smooth. Two cones on the right were created in modo. Similar faceting on the lower poly version.
3255.19 In reply to 3255.18
Hi danperk, yes that is interesting that the same artifacts are present in natively created Modo geometry as well.
This kind of artifact gets reduced when polygons get smaller in size on the screen, so increasing the vertex count around the circular direction is one way to do that, but also doing a few vertical divisions is another way.
But you really should not need to go to such a high density to avoid these artifacts in a full render, it would be better if the full render did a more proper vertex normal interpolation so that you could get nice results with lower polygon counts.
Taking some shortcuts in interpolation can help to speed things up, maybe this is an area where some quality was sacrificed intentionally for a speed gain, but it would be good to have an option to control that if that was the case.
3255.20
A strait cylinder created in Modo seems to be pretty smooth beyond 12 sides, so it seems to be
the cones angle where the render has problems.
3255.21 In reply to 3255.20
Maybe some combination of the cone's angle making some greater variation in shading, along with the cone's taper causing the polygons to have different widths at the bottom versus the top. That may have some kind of subtle effect on the stuff being interpolated across the polygon.
3255.22
Once again I fear the render problems is due to the codebase within Lightwave.
Since Modo was lifted from Lightwave, it has inherited the same problems - incorrect support for supplied normal information.
As Michael proved using Cinema 4D, if the normals are handled correctly, the objects should look exactly the way they do in MoI.
(And that's the reason why I went broke purchasing C4D since it was the best at importing MoI objects...)
I plan on showing any artifacts and discussion threads like this in the CORE forums to try and make sure CORE will be as good as C4D in handling MoI imports.
I eventually want to let C4D and stick exclusively with LW but I can't if it's not going to provide similar results.
-Will
Show messages:  1-7  8-22
