Bug reports
3252.1
Just wanted to know if there is a designated place to report bugs (similar to the boolean problem)? Or should I just post in the forums? The latter seems better as it might help better to inform others of the problems.
While we're on the subject of bugs. I have another to share.
I'm having a strange problem when working with a Helix curve. If I create a Helix curve then another curve (any form) and try to rotate/scale/adjust the curve (not the Helix) it causes my system to slow down dramatically (can take up to a couple minutes just to rotate/scale/adjust). If I hide the Helix, I can work as usual on the other curve without slowdown. So apparantly only when the Helix is visible.
3252.2 In reply to 3252.1
Hi Tree,
Yes, please just post in the forum or send me an e-mail if you have a file you don't want to share.
Also, it definitely helps for me to have an example file to work with.
re: helix slowdown - you may be running into a problem where it can be slow to calculate apparent intersection snaps on some longer helix curves.
Does it go away if you uncheck "Use apparent intersections" under Options > Snaps > Object snap options?
Also can you please post (or e-mail to me at moi@moi3d.com) a 3DM model file with those curves in it so I can try to reproduce the problem over here with the same data?
3252.3 In reply to 3252.2
Yes. Unchecking the "use apparent intersections" did help the performance considerably, but not 100%. After deactivating all snapping, I could work without any form of performance loss. Of course, this is not the most optimal solution, since the snapping is a vital part of my workflow.
3252.4 In reply to 3252.3
Hi Tree, thanks for posting the file.
Over here, it seems that disabling apparent intersections actually solves the problem completely. And this is on a 6 year old machine with an old video card...
What degree of performance lag do you still see with it disabled?
It's going to be difficult for me to fix this for v2, I'm probably going to have to add it to my list to look into for v3. It's probably not feasible to really speed up the calculation itself, I'll need to figure out something else, like maybe not doing an apparent intersection on a curve that ends up doubling over itself so many times like this, or possibly doing it on a separate thread.
For now there are a variety of workarounds though - hide the helix, turn off apparent intersections, or disable snaps temporarily while working just in that area where the helix is at... You can also hold down Alt to temporarily disable snaps instead of using the toggle button in the UI.
3252.5 In reply to 3252.4
Thanks Michael,
Yeah, I just put it in a different layer and hide it when I need to change something. Maybe the performance hit has something to do with the virtual machine (VMWare Fusion) running on my mac. I'll have to do further testing sometime later.
