Hello I am using MOI to translate Solidworks 2008 and 2010 files into quad geometry for rendering in Modo.
All  1-8  9-11
3250.9 In reply to 3250.7
Hi skateboardkid, now that I read your message more carefully I see that you did already try using separate surfaces and that you got that big 1.4 Gig file when doing that.
That is due to a problem that MoI v1 has in dealing with an IGES file that has many solids in it instead of only 1 solid in it. MoI v1 gets confused when it tries to join all those surfaces into solids, it can mistakenly try to join pieces together that came from adjacent touching solids and that can make a big mess.
That is fixed in MoI v2 - in MoI v2 only surfaces that belong to the same "level" in the IGES file are attempted to be joined to one another.
For MoI v1 you are best off exporting only one part at a time instead of exporting multiple parts into one single IGES file.
It is also possible to turn off automatic joining on import, in MoI v2 it is a setting in the options dialog, but in MoI v1 it is in the moi.ini file only.
3250.10 In reply to 3250.9
I am still having some problems with the exported geometry - the are are some surfaces doubled up and most main fillets have flipped normals.
Maybe I can send you a couple more small files and you can send them back to me out of v2?
The geometry looks unbelievably good in the preview window and I would just love to resolve this issue without bugging you too much, I have tried adjusting nearly every setting in MOI and in the IGES export in SW. I am not going to run test until I am out of options tonight and then get back to you in the morning.
3250.11 In reply to 3250.10
Hi skateboardkid, yes certainly send me some sample models if you can.
I've actually heard back from the guy who makes the IGES translators that I use and the problem with that one type 186 model that would not come in should be fixed for the next v2 beta. It was actually an error in the IGES structure that SolidWorks created for that one model with a void pocket in it.
If you're using v1 this can happen if you have multiple solids within a single file and those solids have overlapping or touching pieces.
To avoid it, there are a few options - the best is to use v2 where that is solved, or you can only export one solid per IGES file instead of putting multiple parts inside of a single IGES file, or you can turn off automatic joining which in v1 is an option inside of the moi.ini file that you have to edit with a text editor like notepad.
That can end up happening if pieces did not join together into a complete solid.
In v2 you can tell if an object is a solid or not by the object type indicator that shows up in the upper right corner of the window that gives some information about the selected objects.
Show messages: All  1-8  9-11
