Feature Request
3234.1
Hello
is there going to be a Curvature Graph and Rebuild Surface / Curve Feature?
thank you
cheers
3234.2 In reply to 3234.1
You have yet a "rebuild" when you draw something ;)
Just not call any function after the last drawing
Show points move it or move resize... etc curves generator ;)
= rebuilding of curves, surfaces, objects!
3234.3 In reply to 3234.1
Hi ksiksu,
In the most recent Dec-19 v2 beta release there is a new Rebuild command available which can be used to rebuild curves.
You have to set up a keyboard shortcut or type in the command name to launch it though, there is not an icon for it in the UI yet.
In the future I do want to also add in surface rebuild and curvature graph functions, but I don't know exactly when that will happen yet. MoI is currently more focused on simple, quick and easier to use tools rather than those kinds of intensive mathematical NURBS oriented stuff.
3234.4 In reply to 3234.3
hi Michael
i understand this. thanks for response.
will the scripts/functions be later implemented into the menu?
cheers :)
3234.5 In reply to 3234.4
Hi ksiksu, yes I do want to have a menu item or button somewhere for some additional things like Rebuild, I just have not quite figured out where to put them yet.
3234.6 In reply to 3234.5
The hoi polloi are growing in numbers!
Brian
