Points on All Primitives
All  1-3  4-14
3227.4 In reply to 3227.3
Hi Brian, yeah actually another thing you can do instead of Edit/Separate is to select the caps and delete them, leaving only the cylinder or cone surface which can then have points turned on.
Then after you have squished the points around if the end is still planar you can use Construct > Planar to recap it, it looks like you have probably already figured that out.
It's those end caps on a cylinder or cone that are trimmed surfaces, they are a larger plane that has been trimmed down to a circular outline.
3227.5
Hi Brian.
You can easily make your own single surface primitives:
Cone = Revolve
Tube = Revolve
Cylinder = Revolve
Box = Rail Revolve
Just be sure that your input curves don't have any sharp points, and they will remain single surface and point-editable. The control point structure of the input curves will determine the point structure of the resulting surface...
jonah
3227.6 In reply to 3227.5
Hi jonah, actually it is not necessary to do anything special to set up a control point editable box in MoI unlike Rhino.
That's because MoI has a feature where it also allows you to turn on control points for a polysurface if the polysurface is made up of untrimmed surfaces that are joined to one another along a natural surface edge.
So in MoI you also don't need to worry about not having sharp edges in your revolve profile, the part that you do have to worry about is planar end caps since those are trimmed planes.
3227.7 In reply to 3227.6
Hi Michael. I was assuming that Brian wants to manipulate these in some way, perhaps make them "squishable" as with the sphere primitive...
3227.8 In reply to 3227.7
Hi jonah,
> sphere primitive...
I guess you mean making more internal points for the box? Yeah if you want to have more points to squish around instead of only points at the box corners then you may still want to use rail revolve for that.
But you do not need to worry about the sharp corners in the revolve profile preventing control points from being turned on like you do in Rhino, since MoI allows points to be turned on for objects made up of more than one joined surface if the joins are at natural surface edges.
Of course if you want to have a totally smooth shape throughout then you should not have any sharp corners in the revolve profile since you will be starting out with sharp corners in that case.
3227.9 In reply to 3227.8
Michael/Jonah
Jonah's idea adds a lot to modelling approaches. Whacco!
Between the two of you it really reduces the need to work with poly apps .
Brian
EDITED: 6 Jan 2010 by BWTR
Size: 176.2 KB, Downloaded: 48 times, Dimensions: 1024x640px
3227.10 In reply to 3227.8
Hi Michael. A similar thing can be done in Rhino by using the SurfaceCreasing plugin, which allows you to output a creased single surface from commands such as Extrude, Sweep, Loft, etc. Any kinks in the curve will become a crease. Of course, it has the same toplological restraints as a single surface. But it can be point edited... It can be a very useful tool, but dangerous in the wrong hands! Many times resulting in the question "why can't i fillet this edge?". And the usual response "because there is no edge there!" :P
jonah
Size: 72.7 KB, Downloaded: 55 times, Dimensions: 742x494px
3227.11 In reply to 3227.10
Good fun!
Brian
Size: 149.3 KB, Downloaded: 62 times, Dimensions: 1024x640px
3227.12 In reply to 3227.10
Hi jonah,
> is no edge there!"
You'll probably also run into other problems in Rhino with surfaces like that, like meshing not working correctly in all cases on such a kinked single surface and also potentially problems in surface intersection and booleans as well. Also you can't use Explode on that kind of thing to break it into components anymore like you normally would be able to do with a faceted object.
The nice thing about MoI's method is that it just works directly on a polysurface, there is no need to set a special mode to create unusual geometry and so you don't need to run into all those side effects.
3227.13 In reply to 3227.12
Hehe... Yes the meshing is the other question which people always ask. The mesh generates just fine. But the vertices on the crease are not welded as they would be for an edge. So once you move the points, the vertex shading normal sometimes gets a bit screwy... Rhino does have a command to split it into a polysurface, called DivideAlongCreases. So you can continue adding fillets, etc...
3227.14 In reply to 3227.13
Hi jonah,
> fillets, etc...
Yeah, but this is another good example of how Rhino has gotten so far out of hand with such an enormous pile of commands...
MoI just always splits kinked surfaces into a polysurface, but without losing the ability to point edit it.
Basically the need for the extra command has been engineered out of MoI by an improvement in a more fundamental mechanism (just regular turning points on).
Show messages: All  1-3  4-14
