Imported spline
All  1-2  3-5
3224.3
Tnx for the answer Michael! :)
Great technical support! :)
___________________________________
MrBraun - Moderator www.C4dHotline.it
www.MrBraun.altervista.org
3224.4 In reply to 3224.3
Hi MrBraun, no problem!
One thing I should also mention though is that if you have a curve that has sharp corners inside of it (something like a polyline or rectangle), then it is usually good for each Loft profile to have the same number of segments in it.
That's number of joined segments within the curve though (use Edit/Separate to break a curve into individual segments), not control point count.
When lofting a multi-segment curve like a polyline, if all the profiles have the same number of segment then each segment will get matched to one another.
3224.5
Tnx again Michael! :)
Show messages: All  1-2  3-5
