New User Question
All  1-7  8-11
3207.8 In reply to 3207.7
Hi Ryan, so you need to keep on building more pieces before you'll have a solid.
For example one way you could start to do that with what you currently have is to select 2 edges like this:
And then run the Construct > Loft command to build a surface between them:
If you repeat that on down the row there you will then gradually fill in more pieces there and you can then select those pieces and use Join to glue them together into a solid.
But this is a somewhat more tedious way to build things in little fragments like this, things can go a lot more quickly if you build your initial curve structure to have longer curves so that larger pieces of your model are built more right from the beginning.
Or because your shape here seems to have some repetition to it, building one segment as a solid and then duplicating it, then unioning those pieces together could be a good way to go.
I'll see about posting an example for that...
3207.9 In reply to 3207.8
Hi Ryan, also one thing I'd suggest in general is to build your model straddling the x or y grid axes (rather than just hanging out in space somewhere) so that you have a more convenient centerline to snap on to for doing things like mirroring etc...
Either that, or you can actually draw in a centerline early on as a reference as well. But having that centerline well defined and easy to snap on to can help to make sure you keep things accurate.
3207.10 In reply to 3207.7
Hi Ryan, so here is an example of what I mean by making larger pieces more all at once.
I started with this curve setup, which I built by mirroring your original path curve and then using Construct > Blend to make a smooth connecting curve between the pieces, and then Edit > Join to glue them together into one combined curve object:
Then I selected these 2 curves as the profiles:
And did the Construct > Sweep command to sweep those profiles along the rail to build this result:
Now that is ready to be converted into a solid (Sweep will automatically convert some kinds of things into a solid by capping the ends of a tube, but in this case it's more like the "sides of a tube" actually so this one you need to cap with one extra step) by selecting it and running Construct > Planar which will cap off planar open holes in an object, which results in this solid:
That's a file attached here as RyanModel2.3dm if you want to look at the geometry.
Now that you've got a piece built as a solid it can be more easily combined with other pieces by using booleans, like for example here I drew a polyline in the Front view:
Now you can select your solid, and run Boolean Difference and use the line as a cutting object to cut it into 2 pieces like this:
And then delete the piece you don't want:
But one of the main ways to kind of speed things up is to try and invest more time in the initial curve setup and try to build somewhat larger chunks of your model at the same time if possible.
You can kind of get an idea that if you do this with several pieces, you can form components and then combine the components together with booleans...
Hope this helps!
It takes a little while to get used to how to think strategically about how to build your model with fewer steps... One big tip though is to try to spend more time thinking about getting curves arranged and accurately placed as the starting point.
3207.11 In reply to 3207.10
Michael,
This helps immensely, and I truly appreciate the help. I fussed around with it for another hour or so, got 90% of what I want, then took what you had done and got 100% in about 1% of the time following your method.
I think you are right, designing in 3D takes more up front thinking and planning. Getting the layout right from the get go in your head on how to build what you want seems to be a big piece of what I was missing on this.
I'll keep playing around with this, I'm sure I'll have more questions.
Thanks again for the guidance.
Show messages: All  1-7  8-11
