Thanks, I'm glad you like the UI!
I replied to your e-mail about the fillet issue. The next beta has an update to the geometry kernel which has fixed several fillet crash problems.
> Also, am I missing the "project curve" type tool, or is this feature not implemented yet?
It's not implemented yet. As a temporary work-around hack, you can trim a surface with a curve which will involve a built-in projection of the curve on to the surface. Then select the edges, do a "edit/copy", undo the trim and then edit/paste.
