Excellent program
32.1
Wow. It's been quite a while since I was able to open up a new program and immediately use it. Absolutely brilliant bit of UI work here. I ran into a problem earlier and sent a bug report your way. Weird fillet issue. Also, am I missing the "project curve" type tool, or is this feature not implemented yet?
Maybe it's just me, but I get the feeling this could be the NURBS equivalent of Silo.
32.2 In reply to 32.1
Thanks, I'm glad you like the UI!
I replied to your e-mail about the fillet issue. The next beta has an update to the geometry kernel which has fixed several fillet crash problems.
It's not implemented yet. As a temporary work-around hack, you can trim a surface with a curve which will involve a built-in projection of the curve on to the surface. Then select the edges, do a "edit/copy", undo the trim and then edit/paste.
