Groups postponed until v3
 1-20  21-40  41-60
3170.21 In reply to 3170.19
From DannyT (DANTAS)
<Stick to the path you're taking and you have my full support.>
I second that
George
3170.22 In reply to 3170.11
Hi Michael...
>I will probably take at least a few weeks at the start to do some general UI experimentation though.
Interesting, Which area of the main UI you will improve in the next V3 ?
BWT, are you agree if MoI users create Top 10 Wish List ?
From the top 10, you not have to implement all the 10 wish list in V3.
Just for your guide :)
3170.23 In reply to 3170.19
Hi Danny, thanks very much for your (and everyone's) support, I really appreciate it!
3170.24 In reply to 3170.22
Hi Anis,
Initially I want to see how feasible it would be to switch the underlying UI platform off of mshtml.
Certainly - there's actually already a wiki page for that located here:
http://moi3d.com/wiki/Wishlist
That would be a good place to post your top 10 wish list items so that it is with the rest of the wish list stuff and won't get lost.
3170.25 In reply to 3170.24
Michael...
Can I create vote on the MoI Forum ?
3170.26 In reply to 3170.25
Hi Anis, you can create your own forum thread if you want - but I don't have any way for the forum to set up a vote page that takes user submitted data in it like entering your items or stuff like that.
But instead of putting it in a thread, again I suggest to use the wiki wishlist page (http://moi3d.com/wiki/Wishlist) to post your wishlist because that will keep them all in one spot rather than getting submerged into a forum topic where I won't be able to reference it again as easily.
3170.27
I second DannyT's notion, I couldn't have said it better.
Michael excuse my ignorance, but could you elaborate please, not sure what the goals are. (reducing the need for proprietary plug-ins/tools sounds great.) Are you considering an open cross platform friendly solution?
Just curious that's all.
3170.28 In reply to 3170.27
As I configure my own interface by editing the HTML UI files, I am also interested in what this means. So would it still be HTML? Would I still be able to go in and create my own tabs with commands and icons?
Thanks.
Tony
(aka HamSoles)
3170.29 In reply to 3170.28
Uh oh...This statement has opened a hornets nest! :o
3170.30 In reply to 3170.27
Hi Neo,
Really it will just be a bunch of experiments, it may not amount to anything and it is not entirely clear so it is hard to elaborate at this point.
3170.31 In reply to 3170.28
Hi Tony,
I would hope so. If not it would still need to be something similarly controlled by a text file and editable.
Yes, it's important for me to have this same kind of ability to manipulate the UI when I am creating new pieces of UI myself.
3170.32 In reply to 3170.11
I see everyone seems to be going with the QT toolkit especially for the multi-platform support - is that something you're considering Michael?
I don't see Groups doing any more for me than the surfacing exports. So I'm straight without Groups for now.
I'm actually more excited about the 1-rail sweep being able to do proper corners and the other upcoming features you've mentioned!
-Will
PS - Okay I didn't see the bit about keeping HTML before I replied so that'll probably rule out Qt then...
3170.33 In reply to 3170.32
Hi Will, the mitered corners for 1-rail sweep is nearly done, here's a quick example:
3170.34 In reply to 3170.33
3170.35 In reply to 3170.34
Hi Michael, that looks sweet!
Do the pieces end up as individual solids or is the resultant sweep a single solid?
3170.36 In reply to 3170.35
Hi Danny, the result for those cases is just one single solid, all finished up. Also history works to edit the curve and have the solid update to match.
The only part that is not completely finished at this moment is getting the trimming to work between rail segments that are curved instead of line segments.
I'm going to keep working at it here for a few more hours, and if it looks like it is going to take a couple more days to finish that part I will release a new beta without it and then still have another beta release when that part is done.
3170.37 In reply to 3170.36
Another one:
It may not be feasible to have non-planar rails that have curved pieces in them, but you can have them for lines.
3170.38 In reply to 3170.36
HI Michael...
I think we need to have an option not to merge all segment as single solid.
In reality in wooden or steel structure, each segment represent as separate part.
Usually, only circle profile / pipe that we want to merge each others.
Thanks !
3170.39 In reply to 3170.38
Hi Anis - you can just use Edit/Separate after it is created if you wish to have individual pieces.
That method is a general way to break any solid down into component pieces, it works for the results of Extrude, Revolve, Loft, Sweep, etc...
It is going to take me a bit more time to refine the mitered corner sweep, so this next release won't quite be the very last beta still. I wouldn't be surprised if there are also some bugs to fix in some other new functions anyway.
But in the meantime I have released a new Dec-19 beta (http://moi3d.com/beta.htm) - I'll post a full announcement and release notes tomorrow.
Some brief mention of new stuff - there's now a variety of orientation tools such as copy to clipboard with origin (right-click on copy or Ctrl+Shift+C), PastePart (right click on Paste or Ctrl+Shift+V), ImportPart (Right-click on File/Import), and also some new tools under Transform > Orient.
Also mitered corners for sweep, it should be working well for sweeps along polylines, curved segments will work for basic cases but still need some tuneups for some situations.
Show messages:  1-20  21-40  41-60
