Recommended free renderer - An old question, maybe a new answer?
 1-13  14-33  34-53  54-69
3136.34
Argo
Just used BR 5. Funky UI is putting it mildly, but for that price I was determined to figure it out.
I did search for BR 5 video tutorials and searched forums, they were also funky but they did get
me started. Just have to play with it a while.
3136.35 In reply to 3136.31
The new 3D PaintBrush app Ralf mentions above seems pretty good! (http://www.3dpaintbrush.com/)
Introductory price = $99
The UI seems nice and actually easy to use.
It can load a 3DM file directly but it does not seem to do a very good job of producing a mesh directly from the NURBS data, but bringing in OBJ files exported from MoI seems to work well with it. It appears to load in all the vertex normals and material information from OBJ files so that is great.
This may end up being the kind of missing link for an inexpensive but easy to use standalone rendering program.
It may possibly be a little too streamlined though, there does not seem to be very many options exposed for tweaking the rendering like anti-aliasing settings, etc... but it seems like you can get a basic result quite easily. I wish there was an option in it to adjust the view rotation to keep the same "upwards" direction while rotating around though.
I would think this would actually go somewhere near the top of the list to check out for getting stuff done easily.
3136.36 In reply to 3136.31
Argo, you can render in both programs. I had forgotten about DAZ Studio, Since you can import obj files directly into Bryce I never used the other and am unsure just what it is capable of.
- David
3136.37 In reply to 3136.33
Hi Pilou
Attached is the file I used: argo13DS (3DM also attached). I could not seem to select my object inside Sketchup and the Light/Reflect sliders would move but reset back to zero, almost immediately. It did render, but not well.
Your renders are great, and only two minutes as well!!
Thanks - Brendan.
3136.38 In reply to 3136.36
David,
I'm liking DAZ Studio. I picked up the UI in less than 10 minutes from cold, and rendered the attached in 22seconds. For a quick and dirty rendering not bad.
Phil,
Those lightbulb renders in the post you linked to are absolutely amazing! I can see now the incentive to persevere to learn the process.
@Argo: Podium (you can't find more easy render prog and free 500*500 ;) http://www.suplugins.com/
Absolutly no problem :) here no artistic result just test your file :)
Try with the 3ds file : I suggest to "clean" your model with a plug name "Cleanup" by Thomthom (erase coplaner face ...etc)
http://forums.sketchucation.com/viewtopic.php?f=323&t=22920&st=0&sk=t&sd=a&hilit=cleanup
(this erasing can be also to be made without plug at the Importation file/Options)
Then if you want (like me here:) made a red wall and lighting you must Edit Component then select any faces wanted and move cursors!
Your object here arrives with this stucture Component/Component... So you must Edit Component/Edit Component...
An easy method is select by Menu Windows / Outliner
Of course better is export from Moi in SKP ;)
Shadows asked in Sketchup with no Shadows you will obtain an another nature of render
Render 2 minutes 50 in a very old computer more than 7 years old! :)
Any regulates : biebel_settings.xml presets
Center your objects in the Sketchup Screen because Podium in free don't make any position refine
So any faces can be a light or/and a reflector :) ("box selecting line" means that I am in Edition of a Component)
EDITED: 2 Dec 2009 by PILOU
3136.40 In reply to 3136.39
Thanks Pilou,
I'll run Cleanup on the 3DS import and then try again.
By the way - re: "... Of course better is export from Moi in SKP ;) "
Is MOI .SKP export a V2.0 feature?
3136.41 In reply to 3136.40
< Is MOI .SKP export a V2.0 feature?
yes! SAT, STP, FBX & SKP export exist in the V2 beta ;)
3136.42
3136.43
DAZ Studio is really nice, especially when you start working with Puppeteer and add on Animate+.
My other recommendation would be Carrara Pro as well.
Ultimately I'm placing my bets on Lightwave CORE, focusing back on Lightwave will allow me to shed Softimage and Cinema 4D - those packages are too expensive to keep up with especially since currently I'm just a hobbyist...
-Will
3136.44 In reply to 3136.38
Argo,
Thanks for posting your DAZ Studio render, I might re-look at this app as sometimes I need something simple and quick. I really like Blender, and Blender with Yaf(a)Ray but I don't always have the time to set up, assign materials, render, tweak - repeat.
- David
3136.45
Would anyone like me to make a tutorial on using Kerkythea and MOI3D?
3136.46 In reply to 3136.44
David
Your welcome :-) DAZ Studio sits well with the "wiring" of my brain. Other than the "Darthvader" (black) UI it sort of reminds me of the MOI process. Of course that just me and as they say: "results may vary".
George
Downloading IR now. I glanced at this previously and then moved to the other programs for whatever reason. I really need to stop taking a butterfly approach to this! Almost spoilt for choice for renderers (all with their own idiosyncrasies).
3136.47 In reply to 3136.45
Phil
Yes :-)
If you can afford the time of course!
3136.48
Hi, all
My example:
Modeled in Moi and rendering in Kerkythea
Great kerkythea software
Marco (marcorhino)
3136.49 In reply to 3136.48
Nice render there, look great for a rendering engine.
how is the interface?
Cold
| Adobe Photoshop CS | Corel CorelDraw Grahics Suite X3 | Daz 3D Bryce 5.5, Carrara 6 Pro, Hexagon 2.5 | Maxon Cinema 4D R8.2 | Moi 3D |
Gallery
3136.50
hi
i think daz3d (intergrated 3delight) is a really nice renderer with some nice plugins (commercial). some tests with vict. 4 - daz aya. I know that would be better results with cinema4d or other applications. But for quick render really nice...
EDITED: 15 Dec 2009 by APOPHIS
3136.51 In reply to 3136.35
(quote from Michael, 3 Dec 2009)
Hm, I've tested this out and it seems ok...
But I can't seemt o get it to render a png with a transparent background...
Anyone know how to do this?
3136.52 In reply to 3136.51
Hi NightCabbage, if nobody here knows the answer you may want to e-mail 3D PaintBrush tech support which seems to be here: support@3dpaintbrush.com
3136.53
Yeah I did that already but they haven't gotten back to me yet.
Just thought someone here might know - given it's a pretty basic feature?
Show messages:  1-13  14-33  34-53  54-69
