Entering line lengths and circle diameters on the fly
3121.1
When I start drawing a line or circle (and, I'm sure, other things), I specify a starting point and then I have to drag the pointer across the screen the to get to a DRO window where I can start entering a length or other type of value, so I get a long line or a huge circle or sphere on the screen until I can enter the right value. It would be nice to be able to call up a value-entering window right there. I've tried pushing mouse buttons but that doesn't work, I've tried just starting to type, but that doesn't work. Is there a way to make that little calculator-like keyboard pop up so that I can use is anywhere? Oh, and BTW, it would be nice to have a way to specify units on that little keyboard. Just because I'm working in inches doesn't mean I don't need to input in mm once in a while, also.
Mark
3121.2 In reply to 3121.1
Hi Mark,
Actually, just typing is supposed to work - did you possibly switch to some other application and not have MoI as the active application window when you started typing?
You should be able to just type in numbers and push enter without needing to click on anything.
So for example when drawing a line, if you want a line of length 5.5, simply type 5.5 <enter> and it will be constrained to be that length.
If you are drawing a circle and want it to be radius=5.5, when you are the "Pick radius" prompt you can just type 5.5 <enter> without actually needing to click on the control.
Is that not working for you?
When you type numeric digits, the keyboard focus will automatically go into the first available input field.
For drawing a circle, that will be that Radius control.
When drawing a line, it will be the x,y,z input control in the bottom toolbar - you can enter coordinates there like 2,2 for x=2, y=2 or if you enter in a single number that will be used as a distance constraint and the line you are drawing will have its second point restricted to be that specific distance away from the first point.
If typing in does not work for you, can you please give me a more detailed step-by-step description of exactly what you are doing? Like what you are clicking and what you are trying to type.
3121.3 In reply to 3121.1
Hi Mark,
Well, putting all the different possible units on that little keyboard would kind of turn it into a big keyboard instead.
In MoI v2, you can enter in different units by typing them in at the end using the keyboard.
Like if you have units in Inches currently, you can type in 5mm and it will automatically convert that into inches for you.
