WIP Car Wheel
All  1  2-12
3118.2 In reply to 3118.1
Welcome back to the world of 3d modeling! :)
Looks like you are off to a great start, look forward to seeing your updates.
3118.3
Yes Moi is great. I love it to model with no reference. In this case with no correct norm values (wheel nut ). The hardest part was to find a way to bend the center of this wheel. I've project the curve on a sphere and cut the lines. I didn't find an other way. My first try to select the point and move them down was not bad but I couldn't extrude the curve with caps. My test below.
Regards from Bavarian
Size: 99.4 KB, Downloaded: 105 times, Dimensions: 800x600px
3118.4 In reply to 3118.3
Hi Apophis,
Possible for the center hub, some kind of revolve of a profile curve.
3118.5
Hi BurrMan
Revolve- I will do some tests.
Thanx
edit: has you any idea for this kind of curve. my alternative again with proj.
EDITED: 21 Nov 2009 by APOPHIS
3118.6 In reply to 3118.5
Hi Apophis,
In the one i am working on i started from a cylinder and using some boolean operation then fillet on the line selection.
Revolve will do the trick for the curvature. The bar in the wheel was made with sweep 2 rails.
This is another test i did with a plain sphere and cylinder with the boolean and fillet operation
Have you ever seen this one in Rhino http://www.toxiclab.org/tutorial.asp?ID=124
I found that Rhino3d has good tutorial for making a car. I registered on there web site (it is free) and you can download the tutorial parts. the one about the rim should help you out. http://www.rhino3d.tv/english/info/accessdenied.php
or Here http://www.carbodydesign.com/
EDITED: 8 Dec 2009 by SPACELAND
3118.7
my last test this weekend. i'm not funny with revolve. project on a surface was my favorite way - until now :-)
if i've time next week i will try further tests. ähm sorry for entering this treahd. it's not gentlemen like.
regards
Size: 90.4 KB, Downloaded: 72 times, Dimensions: 800x600px
3118.8 In reply to 3118.7
Don't need to be sorry Apophis, better 1 thread of the same subject then multiple with the same subject, easier to follow.
And yes you are a gentleman, you are showing your work. :)
that is much better, did you fillet the lien around the hole for the bolt?
Cold
| Adobe Photoshop CS | Corel CorelDraw Grahics Suite X3 | Daz 3D Bryce 5.5, Carrara 6 Pro, Hexagon 2.5 | Maxon Cinema 4D R8.2 | Moi 3D |
Gallery
3118.9
yes the lines around the hole for the bolts was rounded.
i've found a mistake. the outlines from the centerwheel should be rounded.
this could be a really tricky place to clean ist. :-)
Size: 149.6 KB, Downloaded: 53 times, Dimensions: 800x600px
3118.10 In reply to 3118.9
Yeah you had to pointed out even for me to see it, didn't the first time. Still this is a better wheel there.
Cold
Gallery
3118.11
A new update, started from scratch. (yep that is me changing my mind to often, crazy stuff in there too :P)
Cold
Gallery
3118.12
Update
Cold
Gallery
Show messages: All  1  2-12
