Moi to Blender export - Materials lost
3106.1
When exporting as "lwo" and importing into Blender via the Blender import script
all materials are lost ?! Some happens when exporting as "obj" with and w/o mtl file.
Any help appreciated.
Oliver
www.o5m6.de
Size: 97.9 KB, Downloaded: 106 times, Dimensions: 1024x819px
Size: 49.3 KB, Downloaded: 85 times, Dimensions: 1024x632px
3106.2 In reply to 3106.1
Hi Oliver,
> Blender import script all materials are lost ?!
That seems to be a limitation in the script - it was only written to bring in Points, Polygons, and UV mapping coordinates and does not try to read in any material assignments in the LWO file.
Which OBJ importer were you using for Blender?
I have not tested it myself, but the one here:
http://jmsoler.free.fr/util/blenderfile/py/obj_io_modif232b.py
Seems to say that it will read materials, you may need to set some option to enable it.
3106.3 In reply to 3106.1
Hi Oliver, are you also possibly using an old version of Blender or something?
Over here doing a quick test with the default OBJ importer in Blender 2.49 seems to preserve materials fine for me.
Just make sure in MoI under Options > Import/Export > OBJ options, you have both "Write material assignments" and "Write .mtl file" enabled.
This in MoI:
Just using the default Blender OBJ import options which is like this:
Gives me this result in Blender:
3106.4 In reply to 3106.3
thanks again for your fast response, amazing !
Got it now (result below), missed the material checkbox on export.
Oliver
www.o5m6.de
Size: 75.4 KB, Downloaded: 100 times, Dimensions: 866x781px
3106.5 In reply to 3106.4
That sure has turned out great Oliver!
