Hello!
All  1-7  8-10
3093.8 In reply to 3093.7
Just want to make it clear again that these images were made by a friend, called Eduardo (or Edward, as his ID says).
3093.9 In reply to 3093.8
I'm now trying the 30-day trial that has save functions so I can test communication with SketchUp. I'm guessing that .skp import/export is only available in the purchased version, as I can't find them in the trial.
3093.10 In reply to 3093.9
Hi Miguel, .skp format export is only in the v2 beta, it is one of the new features that is coming for the 2.0 release.
The v2 beta is available for all v1 owners to use during the beta period.
There is no SKP import though, only export - SKP is a polygon based format and MoI works on NURBS surface data which is a lot different than polygon data.
MoI can create polygon data from NURBS surfaces by dicing the smooth surface patches up into small facets.
But it is not so easy to go the reverse way and take a bunch of diced up facets and try to reconstruct large smooth sheets from them.
So because of that MoI does not generally import any kind of polygon data, only export it.
Show messages: All  1-7  8-10
