How to write numbers with fractions
All  1-2  3-7
3089.3 In reply to 3089.2
Thanks, but I want to be able to write the whole with a fraction not a whole with a decimal.
3089.4 In reply to 3089.1
Hi Mark, normally those kinds of coordinates are used for feet and inches type units only.
You need to have your unit system set (under Options / General) to something other than "No unit system", and then you can enter in those kinds of coordinates if you include the ' and " marks along with them, like for 8 1/2 feet you enter this:
8 1/2'
Normally when you want that style, you should go to Options / General, and set "Unit system: Feet & Inches".
That will cause the base units to be in feet and all the coordinates and distances will be displayed using that fractional type style, like 8' 2 1/2".
Otherwise if you want to do it for something other than feet or inches that is possible by typing an expression using the + sign, like: 2+1/2 , that will result in 2 + 0.5 = 2.5 units.
Using the + method will work with any unit system and not just for feet and inches.
3089.5 In reply to 3089.3
You type 2/5 and moi convert automatically the result!
Only result is sufficient no? ;)
and 2 +(1/2) will more prudent for complex formula ;)
3089.6 In reply to 3089.5
It's not bad to use ( ) to clarify things especially if you have a longer expression.
But multiplication and division do have higher precedence than addition and subtraction, so for this case you don't need the ( ) and can just write: 2+1/2
That will automatically evaluate as: 2 + (1/2)
3089.7 In reply to 3089.6
Yes but remember precedence is more difficult than write () :)
Show messages: All  1-2  3-7
